547,126 active members*
2,910 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > Kitamura HX300, 1999, Fanuc 16, Palet alarm 2014
Results 1 to 4 of 4
    Junior Member
    May 2010
    201
    Hi!
    After the fuse in operator panel next alarm appeas.
    The machine alarm in "14" - looks like switched.
    Any ideas?
    Junior Member
    May 2010
    201
    Re: Kitamura HX300, 1999, Fanuc 16, Palet alarm 2014
    The problem was in air sensor.
    This sensor is under the pullet.
    It inform about air pressure change (the diff from low to high pressure till 1 Atmosfere)
    I blocked this sensor and connected the chain to other sensor: the pallet on(off).
    2014 error disappeared.
    Sep 2021
    I can't find sensor
    Sep 2021
    Please help me to fix the error
  1. Replies: 12
    Last Post: 12-26-2016, 10:31 PM
  2. Kitamura Mycenter HX300 build in 1999
    By =aike= in forum Kitamura
    Last Post: 11-25-2016, 09:00 AM
  3. Replies: 1
    Last Post: 09-09-2015, 12:44 PM
  4. 1999 VF3 HAAS Alarm# 175
    By rnorris in forum Haas Mills
    Last Post: 09-10-2010, 09:27 PM
  5. Kitamura 3xi w/ Fanuc 16i Alarm problem
    By thamain1 in forum Fanuc
    Last Post: 09-08-2006, 09:03 AM
