Ebay link
https://www.ebay.com.my/itm/230V-POR...UAAOSwga1gL5jl
Motor with brushes
Versitale and handy, thanks to light weight easy transport to the job site.
Cuts everything from PVC over brass to stainless steel.
Adjustable blade guide with roller bearings.
Stepless cutting speed adjustment.
Rugged ground plate with rubber feet and well-balanced design guarantee a smooth run-
Blade tension conveniently adjustable via handwheel at saw arm frontside
Spring-supported saw arm steering.
Performs miter cuts up to 60°.
Solid saw arm with transport lock and spring down feed control.
Included in delivery: sawblade, vice, and workpiece limit stop.
Technical data:
Motor: 230 V / 50 Hz 400 W
Cutting performance round 90°: Ø 75 mm
cutting performance round 45°: Ø 60 mm
Cutting performance LxH 45°: 50 x 50 mm
cutting performance LxH 90°: 60 x 60 mm
Saw band speed: 35-80 m/min
Saw band: 1435 x 12,5 x 0,6 mm
Net weight: 24 kg
Gross weight: 26 kg
Packaging dimensions: 720 x 380 x 450 mm
Same product as much order from https://www.northerntool.com/shop/to...9539_200659539
1 1/2 HP, 115/230V single-phase motor
4 blade speeds: 80/130/180/235 FPM
Durable, high-quality 93in. x 3/4in. bi-metal blade
Capacity: 7in. round stock; 7in. x 12in. rectangular stock
Safety hydraulic downfeed offers maximum control
or you can get the same product at Northern Tool Coupons as well at a discount.
