585,567 active members*
3,555 visitors online*
    Mar 2021
    Komo Router head adjustment
    Hello,
    I want to know how to true up the head on a Komo VR 522 router. When I fly cut the table it is off and I need it to be within spec or look flat when fly cutting. I cannot find any info on how to do this?
    Thank you,
    Joe
    Nov 2017
    4
    Quote Originally Posted by Doc-Joe View Post
    Hello,
    Thank you,
    Joe
    There are typically (4) hex socket head cap screws that secure your spindle motor.
    This is by no means a professional explanation but I have a cnc shop and 2 komo router.
    get an indicator, supply a true surface (or use your tables surface)
    Insert indicator in spindle
    Activate your spindle (lower to cutting position) similar to
    Tool touchoff
    Loosen screws.
    Correct the motor using feeler shims for x axis
    Move the spindle motor clockwise or counter clockwise for y axis
    Hope that helps!
    Jun 2005
    1729
    Question Re: Komo Router head adjustment
    Quote Originally Posted by arrowdesignllc View Post
    Tool touchoff
    Loosen screws.
    Hope that helps!
    Buy or make a head trimming guage. Search trimming CNc head and you will find videos on YouTube
