600,789 active members*
4,360 visitors online*
Results 1 to 5 of 5
    Nov 2012
    KUNAKI - Fanuc 15M
    Please for help ... I have Alarm EX 056 ATC INTERLOCK (TWIN ARM) what it means and what I must can do ..... Please tel me were i can find list all EX alarms machine is KURAKI KBT 11 WDX - Horizontal Boring & Milling .. Programing Funaci .. THANK YOU :wave:
    Dec 2009
    54
    Assuming this is a KURAKI.
    The "Twin Arm" is the tool changing arm.
    You should look up "EX056" in the error codes in the back of your manual for specifics.
    Possibly your tool changing arm is out of position or you have a faulty limit switch, hydraulic solenoid, or your hydraulic pressure is low.
    Sep 2010
    80
    Quote Originally Posted by valentin zalik View Post
    .. THANK YOU :wave:
    The tool trolley is out of position. Do you still have the issue?
    Nov 2008
    37
    Hi, Do you still have this kuraki?
    I lost parameter on this kuraki unlucky I don't have backup keeprelay, timer and counter. If you don't mind to share these parameters, thank you for your kindness
    Re: KUNAKI - Fanuc 15M
    Same issue as mluqman. I could use a copy of your parameters.
