570,482 active members*
4,196 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > Laser CO2 Tubes, Diodes, RF and Power Supplies
IndustryArena Forum: Laser CO2 Tubes, Diodes, RF and Power Supplies
Page 1 of 9 123
Threads 1 to 20 of 178
Laser CO2 Tubes, Diodes, RF and Power Supplies here.
  1. Golden Laser JGSH-13070
    Started by RCjunkie, 04-14-2023 04:38 AM
    04-14-2023, 04:38 AM Go to last post
    02-14-2023, 10:21 PM Go to last post
  2. Need help with PWM laser control in Mach3
    Started by garymiller397, 01-03-2020 09:06 PM
    12-01-2022, 07:55 PM Go to last post
    05-24-2022, 02:35 AM Go to last post
  3. Laser tube hisses but does not fire
    Started by jaymez10, 08-22-2017 04:56 PM
    fire, laser, power, test, tube
    05-17-2022, 10:48 PM Go to last post
  4. 100 Watt laser tube beam dia.
    Started by Lasertymes, 02-07-2022 01:25 AM
    2.5mm, beam, dia, laser, tube
    02-07-2022, 04:36 AM Go to last post
  5. Stepper motors and timing gears and belts.
    Started by Bpoolrock, 01-14-2022 03:02 AM
    belts, cnc, motor, size, stepper
    01-14-2022, 07:20 AM Go to last post
    12-14-2021, 11:31 PM Go to last post
  6. Invert laser TTL logic
    Started by najmpierre, 12-11-2021 01:34 PM
    cnc, gnd, invert, laser, ttl
    12-11-2021, 01:34 PM Go to last post
  7. Realistic life of Chinese laser tubes
    Started by SRT Mike, 03-22-2012 09:30 PM
    3 Pages
    1 2 3
    factors, not, since, then
    10-30-2021, 01:16 AM Go to last post
  8. Laser beam wobble
    Started by mcdonald79, 10-22-2021 06:58 PM
    10-22-2021, 08:18 PM Go to last post
    10-22-2021, 06:10 PM Go to last post
  9. diy CO2 laser tube
    Started by AndreiBogdan, 01-04-2021 06:04 PM
    10-15-2021, 03:51 PM Go to last post
  10. Laser Tube Size Clarification
    Started by rlrcstr, 05-12-2021 10:57 PM
    hours, laser, lifetime, price, tube
    05-27-2021, 06:23 AM Go to last post
  11. Synrad 48 tube with a Trocen AWC708 plus?
    Started by drumsticksplint, 03-03-2021 04:28 PM
    03-24-2021, 02:56 PM Go to last post
  12. Co2 laser tube producer outside chin
    Started by Reidarr, 12-24-2020 11:45 PM
    12-25-2020, 02:40 AM Go to last post
    12-22-2020, 03:27 AM Go to last post
  13. Laser power suddenly reduced
    Started by Mechanikum, 10-16-2020 04:47 PM
    10-17-2020, 11:41 AM Go to last post
  14. Does this look like a good 80w RICI firing? (video)
    Started by 34ford, 09-11-2020 05:37 PM
    80w, bad, firing, good, rici
    09-11-2020, 05:37 PM Go to last post
  15. 40w to 80w wiring question (FSL MUSE)
    Started by Cwcustomworx, 08-24-2020 11:33 AM
    08-24-2020, 01:21 PM Go to last post
Page 1 of 9 123
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
