here are the pictures, the before is how small my text is and when I went to preview or print, it come out huge
I don't see a problem. Your text is exactly the same size (96x62mm) in both the program window and the preview window.
is the program bed layout the size of your bed.
so for bugging you so much, but how do I change the size of my bed layout, I have I believe a 700mm x 500mm
thanks
Open your RDworks and under config there is page settings you can change it there
Bed size has nothing to do with it. If you set your text size 96mm x 62mm thats what the machine should cut. Unless you have a mm to inches conversion going on or a scaling issue.
Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
not sure if i have mm to inches conversion going on, how do I fix that
thanks
- - - Updated - - -
thanks, can't wait till I get home to try it out
You say Print or Preview? If you convert to gcode how big does it actually cut, set your machine zero up so it just cuts in the air. If it try's cut or engrave 96 inches instead of 96 mm you will see.
Most if not all Chinese lasers are set up for mm's. My USA made ULS could do either inches or mm's,
how do I do that?
thanks
under config para settings DXF MM or Inch
what is the size of attachment image (text1)?
