562,490 active members*
3,721 visitors online*
Results 1 to 1 of 1
    Nov 2022
    Laser not firing
    Hi
    I have a redsail x700 laser. I recently cleaned the machine. Cleaned the mirrors and the bed only. I went to turn machine back on and would not cut would only burn a line. Trouble shooted with China and they recommended to replace tube and power supply. I did because they were probably due to be changed any way. Laser with fire when I press the test button on the Power supply but will not fire when I press pulse button. Cannot check mirror alignment without it. Replaced tube so need to make sure I am aligned. So I’m thinking it is a wire that is loose or something. Pulse worked before all this. Laser just wouldn’t cut so I replace tube and supply. Can anyone help me with this?
    Nov 2008
    623
    Re: Laser not firing
    You could prop some wood directly in front of the tube. It will also glow pink if it’s operating.
