544,218 active members*
3,010 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Lb15 150 Alarm-A Coupling Device Illegal 4
    May 2011
    17
    Hi
    After a year of the lathe being down I put new bubble memory in the machine and loaded the control tapes.
    The machine now has an alarm 150 alarm-a coupling device illegal 4.
    I seem to recall there was a plug in the round parallel port that had a wire jumping some pins because we don't have the Lns barfeeder installed.
    The plug isn't there anymore as someone removed it without knowing what it done.
    The control is a Osp 5000L. The machines a 1984.
    Does anyone know what pins need to be jumped to make the alarm go away?
    Thanks Brent
    Mar 2018
    55
    Re: Lb15 150 Alarm-A Coupling Device Illegal 4
    Hello,
    I have a couple of pictures for our LB15. It is a 1987 with the OSP5000L-G control. Perhaps this will help you solve your issue.
    Good Luck,
    Dave
    May 2011
    17
    awesome can you send them thru to me please?
    Mar 2018
    55
