547,127 active members*
2,922 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Leadwell MCV-OP 1992 Fanuc OM-F Parameter reload
Results 1 to 4 of 4
    Apr 2015
    16
    We had a connection go bad in our battery box.
    Fortunately, we have a backup copy of the parameters.
    There were some issues loading them from a PC so I had to load some by hand.
    Everything works right except the spindle.
    With a 5000 rpm command, it turns at about 100 rpm.
    To make matters worse, I don't have any manuals for it.
    Our Leadwell dealer that we have bought several new machines from has found some settings for the diagnostics, but nothing changed.
    Where do I start looking?
    Does anyone have a book for this machine?
    Thanks...Rob.
    Re: Leadwell MCV-OP 1992 Fanuc OM-F Parameter reload
    Hello!
    Are there any changes if you command 2500 rpm?
    Aug 2012
    63
    Was the Diagnostics also loaded when you did the Parameters?
    Sep 2021
    bro i need v-30 leadwell fanuc o-mf parameters can you send me yours by email: chfazi35@gmail.com
    thankd
  1. Replies: 12
    Last Post: 08-16-2019, 03:45 PM
  2. LEADWELL LTC-15 Fanuc 0T Parameter loss
    By Kittiwat in forum Fanuc
    Last Post: 05-11-2019, 08:03 PM
  3. Sinumerik 810T RELOAD PARAMETER PROCEDURE
    By tano in forum SIEMENS Sinumerik CNC controls
    Last Post: 09-16-2016, 01:25 PM
  4. need fanuc 0i mate parameter for leadwell v30 m/c
    By prakashin in forum Machinery Manuals / Brochures
    Last Post: 07-10-2012, 06:16 AM
  5. fanuc oi-mc system parameter help leadwell machine
    By mcash3000 in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-07-2008, 04:58 AM
