535,449 active members*
3,175 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > LeBlonde Makino FNC 74: "Losing the part Zero problem."
    Jan 2006
    28
    Red face LeBlonde Makino FNC 74: "Losing the part Zero problem."
    Hello everyone,
    I have a Leblonde Makino FNC 74 VMC machine and been using it for a few months now. So far so good and very reliable, however recently my Machine did not detect the tools being register on the Main Controller Panel. So I got some help online and I got some instructions from Makino service about resetting the motherboard CMOS:
    1) Flip a dip #8 on the UM15 Board. (With the Machine Power Off)
    2) Then Power Up.
    3) Hold the 3 Reset buttons for 10 seconds.
    4) Then power down.
    5) Flip back the dip Switch.
    6) Should be clear.
    I did all of this and it worked wonders. The machine is working fine or so I thought however, when I start a new program or previous part program, not changing any procedures of setting up a part and getting the Part Zero ready and set to go, instead of going to the position it should be going the machine spin out into some weird location unknown to the program and to me. Please help! Many thanks!
    Julio
    (919) 714-2103
    Jan 2012
    15
    I have a Leblonde Makino FNC 74 vmc machine fanuc omb system and servo drive atc original parameters not available pl give me parameters and pmc paramerter
    Email -sureshborude10@gmail.com
  1. Milling a Protptype Aluminum Part 2.5"x2"x3"
    By AllSpeedLLC in forum USA RFQ's
    Last Post: 03-23-2014, 03:51 AM
  2. Replies: 3
    Last Post: 10-07-2013, 01:43 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 05-06-2013, 09:59 AM
  4. Losing my "Y" zero position after power down.
    By revlimit in forum Haas Mills
    Last Post: 08-24-2011, 03:18 AM
  5. Replies: 6
    Last Post: 06-24-2008, 01:14 AM
