531,941 active members*
1,660 visitors online*
Results 1 to 8 of 8
    Linear Rail Mounting Flatness
    Hello,
    Is it possible to achieve flatness necessary for mounting linear ways with a vertical mill? Or must these surfaces be ground or scraped in?
    Application is a hobby 3 axis vertical mill. Not particularly crazy accuracy requirements. Looking through HIWIN manuals they spec a pretty tight flatness requirement. Wondering how critical this really is for accuracy of the ways.
    Jan 2009
    17
    Re: Linear Rail Mounting Flatness
    Go to youtube and look up CNC4XR7. He has some videos where he installed some linear rails on a PM727 benchtop mill.
    Definitely a good resource to watch. Thanks of the recommendation.
    Another question that came up: Looks like Normal (C) precision rails have a height accuracy of about 3 thou. This seems like a pretty big tolerance to me. Seems like I should be looking for the High (H) precision rails, however most places I see them for sale online only sell the standard (im assuming this means Normal) precision. Anyone have any input on this?
    Jan 2005
    11662
    Quote Originally Posted by Tinycafe1972 View Post
    Hello,
    Yes a good quality Mill can machine the required flatness needed for mounting linear rails deburring and stoning is all that is needed after machining, yes you can Grind and scrap them also, this does not always mean that you end up with a better flatness of the machined area
    Mactec54
    Jan 2005
    11662
    Height of the Rails is unimportant it's the overall height of the Bearings that is important when installed, I usually match Grind the top of the Bearings if there is a mismatch more than the Bearing tolerance is allowed
    Mactec54
    How do you grind the top of the bearings? Do you measure the difference in height then remove the bearing and grind?
    Jan 2005
    11662
    Correct in most cases they are in tolerance, if you are looking for perfect then you match grind them
    Mactec54
    Feb 2020
    11
    I recommend you watch This Old Tony's build thread.
    https://www.youtube.com/playlist?lis...rZYL6xBIjxsDzZ
  1. Linear Rail Mounting method
    By Sterob in forum T-Slot CNC building
    Last Post: 12-04-2019, 05:51 PM
  2. Side mounting methods for linear rail?
    By Stinkyz in forum DIY CNC Router Table Machines
    Last Post: 05-08-2018, 12:23 PM
  3. Linear Profile rail mounting hardware
    By jevs in forum Uncategorised WoodWorking Machines
    Last Post: 02-18-2014, 09:54 PM
  4. What Bolt's grade should be used in linear rail mounting?
    By Zaher in forum Linear and Rotary Motion
    Last Post: 06-13-2009, 08:42 AM
  5. Self leveling Epoxy for making linear rail mounting surfaces
    By mackeym in forum Linear and Rotary Motion
    Last Post: 11-10-2008, 11:31 PM
