535,104 active members*
3,021 visitors online*
Results 1 to 7 of 7
    Aug 2017
    Unhappy LinuxCNC Tool Change
    Hi
    I am a newbiie at this CNC lark, and have a Cheap Chinese CNC 300 x 400 Router.
    I am using it with LinuxCNC, and I have followed the instructions on this site to set-up auto tool length adjustment using a probe.
    This works fine when tested. I can st an initial tool length, move the head to a G54 start point, change the tool update the tool length, move to the G54 start point, and it is correct.
    The problem comes when I run a file after setting the initial tool length. It cuts fine, but after it finishes, and LinuxCNC stops and I select tool change the head drives down!
    The code I am using is:
    (probe_tool.ngc)
    O <probe_tool> sub
    G49 ( clear tool length compensation)
    G30 Z0 ( to probe switch)
    G30 ( to probe switch)
    T0 M6 ( to probe switch)
    Which I understand should home the Z axis first then home the X and Y axes.
    Does anyone have any idea what the problem is?
    Sep 2020
    Re: LinuxCNC Tool Change
    The brooks brothers trailers are a US manufacturer of high quality trailers and equipment used in a variety of industries. Our products are used around the world building infrastructure, maintaining energy grids, and improving the flow of resources and products to customers. Under the present ownership since 1975, our brand identity has steadily increased from a small regional market to our current international customer base.
    Jan 2021
    Thank you so much for this useful information. I have to read this blog and it's related to 8 Ball Jacket articles. I’m so glad to read this article.
    Jan 2021
    4
    This Post is giving significant and extraordinary data, I realize that you take the time and exertion to make a marvelous article.
    Jaipur Escorts
    Jaipur Escort
    Escorts in Jaipur
    Escort in Jaipur
    Jaipur Escorts Service
    Jan 2021
    4
    All around awesome focuses you made here..Great stuff...I think you've made some genuinely dumbfounding center interests. Keep up the remarkable work.
    Jaipur Escorts
    Jaipur Escort
    Escorts in Jaipur
    Escort in Jaipur
    Jan 2021
    4
    My Friend Recommended This Blog And He Was Totally Right Keep Up The Fantastic Work.
    Escorts in Jaipur
    Escort in Jaipur
    Jaipur Escort Service
    Jaipur Call Girls
  1. Replies: 6
    Last Post: 05-10-2016, 12:30 AM
  2. Replies: 2
    Last Post: 05-03-2016, 06:30 PM
  3. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  4. EMC2 name change to Linuxcnc
    By chester88 in forum LinuxCNC (formerly EMC2)
    Last Post: 01-30-2012, 05:50 PM
