547,432 active members*
2,007 visitors online*
Results 1 to 7 of 7
    Apr 2013
    34
    Long string in C code
    Hi, Tom
    Version 4.35f
    I want to use long constant 2D array string with dependence of RPM on PWM frequency of my spindle. When I paste it in C editor window Kmotion stops working. When I try to #include file with it to my code it does not compile. Looks like there is a length limit.
    Is there any other way to use this array?
    This is the string:
    double spindle_pwm=((5,0.000000),(6,0.000000),(7,0.000000 ),(8,0.000000),(9,0.000000),(10,0.000000),(11,172. 981068),(12,306.17),(13,315.544674),(14,344.282368 ),(15,373.545116),(16,392.323716),(17,427.690896), (18,458.933405),(19,485.601278),(20,530.027746),(2 1,582.118407),(22,606.341335),(23,630.459399),(24, 658.837122),(25,680.600429),(26,702.888783),(27,72 8.641898),(28,752.564990),(29,785.052337),(30,804. 895657),(31,837.743215),(32,857.601289),(33,883.02 4128),(34,914.521600),(35,935.684902),(36,965.9224 56),(37,990.040797),(38,1013.364194),(39,1036.3423 21),(40,1058.900796),(41,1085.073498),(42,1111.471 371),(43,1139.338853),(44,1167.416256),(45,1190.07 9484),(46,1214.827498),(47,1236.140787),(48,1257.9 64363),(49,1291.367026),(50,1314.240124),(51,1335. 013332),(52,1366.586028),(53,1388.154170),(54,1410 .307175),(55,1437.154654),(56,1462.727601),(57,148 8.390542),(58,1516.453289),(59,1534.407247),(60,15 61.960449),(61,1583.678749),(62,1610.136608),(63,1 632.154852),(64,1659.962635),(65,1681.920446),(66, 1708.017914),(67,1739.875010),(68,1760.228372),(69 ,1783.296659),(70,1805.120590),(71,1836.783535),(7 2,1857.166687),(73,1880.609890),(74,1905.448060),( 75,1935.700647),(76,1952.378810),(77,1981.130994), (78,2001.949324),(79,2027.357284),(80,2051.040383) ,(81,2071.199304),(82,2096.217722),(83,2119.960954 ),(84,2147.513757),(85,2170.177037),(86,2185.31074 3),(87,2221.0),(88,2257.0),(89,2294.590836),(90,22 98.220591),(91,2323.358574),(92,2339.018253),(93,2 369.945831),(94,2393.569041),(95,2410.502835),(96, 2443.980117),(97,2459.608871),(98,2499.984601),(99 ,2519.782762),(100,2537.376299),(101,2559.485088), (102,2581.322720),(103,2605.351572),(104,2631.3301 78),(105,2654.623320),(106,2679.146579),(107,2711. 948749),(108,2734.326418),(109,2750.764939),(110,2 774.822293),(111,2803.395448),(112,2828.638030),(1 13,2855.590810),(114,2881.374490),(115,2899.343806 ),(116,2907.548152),(117,2937.170790),(118,2967.36 3026),(119,2989.711600),(120,3001.574874),(121,304 0.645958),(122,3063.519122),(123,3086.647266),(124 ,3090.351968));
    Apr 2013
    34
    Re: Long string in C code
    Another problem has arisen, I will not create a new topic. I am setting up a new lathe. I set up both axes, they move good in Kmotion step response, from C code and manually in KMotionCNC. But when i try to use G code (like G0 X0 for example) nothing happened. Also I cant move manually by steps both from keyboard with Ctrl and from screen button. When pressed screen button appears message like "Soft Limit Actuator 103126 Limit 1000000 X+ Rapid Traverse Job Halted" although the limits are still very far away.
    Junior Member
    May 2006
    3889
    Hi mk,
    Since the PWM value is an incrementing value it isn't needed in the array so a simpler 1D array of doubles might be used. Here is ab uexample:
    Code:
    #include "KMotionDef.h"
    double spindle_pwm[]={0,0,0,0,0,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,
    		172.981068,306.17,315.544674,344.282368,373.545116,392.323716};
    main()
    	int i=12;
    	printf("Index %d Value %f\n",i,spindle_pwm[i]);
    Post your Initialization C Program and all of your KMotionCNC Tool Setup Screens
    TK
    http://dynomotion.com
    Apr 2013
    34
    Quote Originally Posted by TomKerekes View Post
    Hi mk,
    It is till too long
    (0 , 0 , 0 , 0 , 0 , 0, 0 , 0 , 0 , 0 , 0 , 172.981068 , 306.17 , 315.544674 , 344.282368 , 373.545116 , 392.323716 , 427.690896 , 458.933405 , 485.601278 , 530.027746 , 582.118407 , 606.341335 , 630.459399 , 658.837122 , 680.600429 , 702.888783 , 728.641898 , 752.56499 , 785.052337 , 804.895657 , 837.743215 , 857.601289 , 883.024128 , 914.5216 , 935.684902 , 965.922456 , 990.040797 , 1013.364194 , 1036.342321 , 1058.900796 , 1085.073498 , 1111.471371 , 1139.338853 , 1167.416256 , 1190.079484 , 1214.827498 , 1236.140787 , 1257.964363 , 1291.367026 , 1314.240124 , 1335.013332 , 1366.586028 , 1388.15417 , 1410.307175 , 1437.154654 , 1462.727601 , 1488.390542 , 1516.453289 , 1534.407247 , 1561.960449 , 1583.678749 , 1610.136608 , 1632.154852 , 1659.962635 , 1681.920446 , 1708.017914 , 1739.87501 , 1760.228372 , 1783.296659 , 1805.12059 , 1836.783535 , 1857.166687 , 1880.60989 , 1905.44806 , 1935.700647 , 1952.37881 , 1981.130994 , 2001.949324 , 2027.357284 , 2051.040383 , 2071.199304 , 2096.217722 , 2119.960954 , 2147.513757 , 2170.177037 , 2185.310743 , 2221 , 2257 , 2294.590836 , 2298.220591 , 2323.358574 , 2339.018253 , 2369.945831 , 2393.569041 , 2410.502835 , 2443.980117 , 2459.608871 , 2499.984601 , 2519.782762 , 2537.376299 , 2559.485088 , 2581.32272 , 2605.351572 , 2631.330178 , 2654.62332 , 2679.146579 , 2711.948749 , 2734.326418 , 2750.764939 , 2774.822293 , 2803.395448 , 2828.63803 , 2855.59081 , 2881.37449 , 2899.343806 , 2907.548152 , 2937.17079 , 2967.363026 , 2989.7116 , 3001.574874 , 3040.645958 , 3063.519122 , 3086.647266 , 3090.351968)
    Junior Member
    May 2006
    3889
    Why is it too long?
    Can you see you used different syntax?
    TK
    Junior Member
    Jun 2014
    18
    Quote Originally Posted by mk00 View Post
    It is till too long
    Split & format its string, such as:
    ( 0 , 0 , 0
    , 0 , 0 , 0
    , 0 , 0 , 0
    , 0 , 0
    [..etc..]
    Apr 2013
    34
    Why is it too long?
    I cant paste it in C code
    Quote Originally Posted by ukr View Post
    ( 0 , 0 , 0
    , 0 , 0 , 0
    , 0 , 0 , 0
    , 0 , 0
    [..etc..]
    It is working, thank you!
  1. String serving machine
    By dmh13433 in forum General Other Machine Discussion
    Last Post: 12-01-2018, 12:25 AM
  2. 18T dowload to pc no eob just long string
    By karlbushnell in forum Fanuc
    Last Post: 01-28-2011, 02:55 PM
  3. String length
    By FGREF in forum SIEMENS > Sinumerik 802D/840D/810D/828D
    Last Post: 06-07-2010, 06:44 AM
  4. Zap String
    By Aplus in forum Bridgeport / Hardinge Mills
    Last Post: 11-04-2009, 05:01 AM
  5. String transfer to G-command
    By beno in forum SIEMENS -> GENERAL
    Last Post: 06-17-2009, 05:26 AM
