545,767 active members*
1,834 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Looking for a decent used ATC spindle - 2hp to 5hp range.
Results 1 to 5 of 5
    May 2008
    41
    Title says it. I'm looking for a decent used ATC spindle - 2hp to 5hp range.
    Thanks,
    BH
    Mar 2017
    839
    Re: Looking for a decent used ATC spindle - 2hp to 5hp range.
    You'll have to provide more info if you expect anyone to be able provide an answer that's worth anything.
    "Decent" doesn't mean anything unless you state what it's to be used for (I.e. What it will cut), what type of machine it's going on (a decent spindle for a 5 ton mill would tear apart a homemade wooden gantry router), what type of parts (for the level of precision) etc.
    And... Your budget. Atc spindles range from $1500 to $50,000+
    May 2008
    41
    I'm not too worried. If someone has a USED 2 to 5 hp ATC spindle to sell I'm sure they would contact me to discuss the details.
    BH
    Nov 2013
    1212
    'good' and 'decent' are hard to define......but one thing is true is that 'good' and 'decent' ATC spindles in your power range are as rare as hens teeth second hand.
    If they are 'good' or 'decent' they will be retained and used.
    I have an 800W air cooled asynchronous (24000rpm) spindle made by a German company called Mechatron. I've had it for six years and I don't know how many thousands of hours use
    I have had....but many. For my new mill I would dearly like another from the same company (ATC with SK25, 42000rpm, S1 2.5kW) but at 5700 Euro its not going to happen anytime soon.
    https://www.mechatron-gmbh.de/en/
    Jianken have a good reputation, and there's a guy here in NZ who has one and he reckons they are great.
    https://www.jian-ken.com/products
    S1 3.2kW, 230VAC, 24000 rpm @ 800Hz excitation, either BT30 or ISO20,( or it it ISO25?) for around $1500USD. That's pretty good value for money and from a credible Chinese manufacturer
    who has been doing serious spindles for years. Still have to save my pennies, but this will be my next highspeed spindle.
    I have a re-manufactured 3kW servo motor (Vickers....Italian from circa 95) which I'm building into a spindle for low speed high torque operations, ie milling steel
    and stainless. So I will keep my eyes open for a spindle cartridge, hopefully with ATC. They are not common second hand and tend to be expensive, say $1500 upwards
    but they do come up if you are patient.
    Craig
  1. HSD 5HP ATC SPINDLE PACKAGE DEAL
    By Dave's_Not_Here in forum Ebay Ads here
    Last Post: 08-22-2018, 08:00 AM
  2. Replies: 0
    Last Post: 10-06-2016, 11:58 PM
  3. Need advice! 2j 2hp head or 1.5hp
    By Cferrell84 in forum Bridgeport / Hardinge Mills
    Last Post: 03-07-2016, 01:26 AM
  4. Colombo spindle ATC 5HP HSK 50
    By EEE_CNC in forum Spindles / VFD
    Last Post: 12-07-2015, 02:05 AM
  5. Interesting source of a decent ATC spindle
    By scarlaton in forum Auto Tool Changer
    Last Post: 07-09-2014, 08:14 PM
