585,741 active members*
4,978 visitors online*
IndustryArena Forum > Community Club House > Mentors & Apprentice Locator > Looking for a mentor: ArtCam + Gerber Sabre 408
    Nov 2017
    9
    Hello forum.
    My name is Danil. I make signs. I've been successfully using Gerber Sabre 408 for cutting profiles but having difficulties with 3d textures.
    Looking for an expert to answer my questions.
    For example:
    recently made a model a woodgrain texture, created a Machine Relief Toolpath and the cnc machine gave an X axis error. The solution was to change the Tool Clearance Strategy to constant-Z, that made the routing process very slow.
    It took 4 hours to produce what' on the image below.
    Thank you.
    Apr 2004
    5734
    Re: Looking for a mentor: ArtCam + Gerber Sabre 408
    This kind of sign is normally made by abrasive blasting. You cut a mask and apply it to the wood, then blast away the background. The wood grain texture emerges naturally, because in a softwood, there's a differential between the hard winter growth and the soft wood that is added in the summer, and the abrasive removes more of the latter. It would go a lot quicker, and the wood grain effect would be more convincing as well.
    Andrew Werby
    Website
  1. Gerber Sabre 408
    By Trifi76 in forum Gerber
    Last Post: 04-04-2021, 08:49 PM
  2. Gerber Sabre 408
    By STYF in forum Gerber
    Last Post: 11-07-2018, 01:31 PM
  3. Gerber Sabre 408
    By bulld101 in forum Gerber
    Last Post: 05-04-2016, 10:20 PM
