585,754 active members*
3,801 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Looking for advice on building a cabinet and frame for a small 5 axis cnc.
    Oct 2007
    6
    Hello,
    I am researching a build for a small tabletop 5 axis cnc machine for mostly 6000 series aluminum and some other softer metals and plastic.
    I would like to build it from off the shelf extrusions using mechanical fasteners. Most of the parts i will be making will be in a size range of 10 mm. I would like to have a tolerance of ±0.1 mm
    Are there any companies with quality parts that will allow me to do this? I have looked at Isel ag as I have worked with one of their machines in the past in a cabinet shop and really liked the quality.
    Ideas, recommendations, thoughts?
    I appreciate the push in the right direction.
    Apr 2004
    5735
    Re: Looking for advice on building a cabinet and frame for a small 5 axis cnc.
    Aluminum extrusions are suitable for making cabinets for enclosing CNC machines, and can provide some of the framework for the machine itself, if one is willing to restrict oneself to relatively soft materials. But I'm having a hard time picturing it being used to build the tilting and rotating parts that would give you 4 and 5 axis capabilities. Do you have any drawings or models that show how you're planning to accomplish this?
    Andrew Werby
    Website
    May 2008
    1185
    youtube videos of the G0704 under the name arizonavideo99
  1. BUILDING A MACHINE AND NEED ADVICE ON 3 AXIS KIT
    By guitarded in forum Want To Buy...Need help!
    Last Post: 10-29-2019, 04:10 AM
  2. Needs Advice - building a small desktop CNC rigid enough to handle metal
    By dvirb in forum Uncategorised MetalWorking Machines
    Last Post: 10-20-2014, 10:31 PM
  3. Any good frame building books out there?
    By Rich05 in forum MetalWork Discussion
    Last Post: 07-08-2008, 09:41 PM
  4. PA Speaker cabinet building
    By mg75 in forum Commercial CNC Wood Routers
    Last Post: 01-06-2007, 04:33 PM
  5. Possible Frame Building Material?
    By scratch_6057 in forum DIY CNC Router Table Machines
    Last Post: 08-04-2006, 04:55 PM
