586,961 active members*
2,891 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Looking for help with settings for Huanyang VFD (1.5kW 110V)
Results 1 to 7 of 7
    Feb 2012
    16
    Hi all.
    I had this VFD working great with my Chinese 6040 router when I used it last a few years ago. But recently I blew the dust off the router and the VFD settings seem to have been reset or otherwise forgotten.
    This is a Huanyang HY01D511B 110V 1.5kW VFD driving a 110V 800W spindle rated at 5A, 400Hz and 24000rpm.
    I have seen many postings for settings for Huanyang 220V VFD versions with different spindles, but none seem to be close enough of for me to figure out the necessary differences. It's been very frustrating since I knew the right settings a few years ago but I didn't record them anywhere. Lesson learned...
    Can anyone recommend the correct settings for the Pd variables?
    Any help would be greatly appreciated!
    Jan 2005
    15362
    Re: Looking for help with settings for Huanyang VFD (1.5kW 110V)
    Quote Originally Posted by Qubert View Post
    Hi all.
    This is all you need, all the basic Parameter Settings are the same for all the 400Hz Spindles, just voltage and Amps that are different
    Don't do a Reset unless you have to, sometimes doing this affects the order of how the Parameters get set
    Huanyang Mactec54
    PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
    PD001=0 (1 For Remote Control)
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
    ( J1 Also Needs to be set for Terminal Control )
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=220 (120 If you have 120v VFD )
    PD009=15
    PD010=8
    PD011=120 ( 100 Minimum Setting with Quality VFD, 120 is Safe)
    PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Acceleration=12 ( Adjust to suit)
    PD015 Deceleration=12 (Adjust to suit)
    ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD141=220 ( Motor Rated Voltage ) (120 for VFD Rated for 120v )
    PD142= ( Motor Max Amps)
    PD142=( 220vSet for your motor Amp Rating 2.2Kw Spindle 9 amp )
    PD142=( 220VSet for your motor Amp Rating 1.5Kw Spindle 7 amp )
    PD142=( 220v Set for your motor Amps Rating 800w Spindle 4 amps )
    PD142=( 120v Set for your motor Amp Rating 800w Spindle 7 amp )
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) =3,000= (24,000)
    PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD72=400
    PD73=120 ( 100 Minimum Setting )
    Mactec54
    Feb 2012
    16
    Thanks for the fast response!
    I'll try these tonight.
    Feb 2012
    16
    Thanks mactec45! Works perfectly and I've now got it under RS485 control.
    One question though... The lowest spindle speed with these settings is 7200rpm. Is that correct?
    Jan 2005
    15362
    That is correct
    If you want to try it PD11=100 and PD73=100, this will give you 6000RPM which is the minimum speed you can run, but do this with caution, watch for a rise in temperature of the spindle when you run at this speed
    Mactec54
    Huanyang Mactec54
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD009=15
    PD010=8
    PD015 Deceleration=12 (Adjust to suit) gf
    PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )ygfy&
    PD72=400
    Hello, i just receive and want to use my spindle that works with a similar VFD.
    i am not sure to understand all that you say here...
    just want to don't do failure
    PD000 i can put the value to 1 after all other PDxxx setup to lock them and keep in security?
    PD001 is to use the VFD onside controls?
    PD002 i want to be sure : i will use a 0-10V PWM converter so i put it to 1 and i have to change the J1 (is it the jumper on the right of wires connexions?) in this case have i to put PD001 to 1 too? or if PD002 is in 1 status it is saying that i can use remote control too?
    My spindle is a water cooled one, so i can use the 100 value to PD011 an PD073? or it is better to keep a minimum of 120?
    i don't understand what value i have to put in PD142 setup? 220? or 7? my spindle is a 1.5kW and 220v type
    For the PD143; how can i know number of pole? is it number of magnets? in rotor?
    and the last one :
    PD144 have to be setup to 3000 if my spindle max speed is 24000 RPM or i have to put 24000?
    Thanks a lot, and sorry about my english, i'm from france and not know all technic words.
    Have a good days !
  1. New machine - G540 - 110V Huanyang VFD - Chinese spindle 1.5kW
    By dubdzine in forum DIY CNC Router Table Machines
    Last Post: 01-24-2024, 05:20 AM
  2. Car hoist 3phase settings on huanyang vfd
    By pietskiet in forum Spindles / VFD
    Last Post: 10-21-2019, 10:04 AM
  3. Huanyang inverter PD settings
    By jamriggsy in forum Phase Converters
    Last Post: 03-15-2013, 04:54 PM
  4. Huanyang 2.2kw VFD, 0-10v 3600rpm settings?
    By EmeraldIsleforg in forum Phase Converters
    Last Post: 09-23-2012, 03:00 PM
