567,250 active members*
4,451 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > Looking for help with TB6560 stepper motor driver.
Results 1 to 1 of 1
    Apr 2007
    11
    Hi, I hope that there are here people that have experience with TB6560 (Chinese) 3 axis stepper motor controller board. I would like to set up since I want to learn and inquire some experience to a field that is new to me. now, my first dilemma is about the E-stop and limit switches. from my experience with machines, the E-stop is a NC switch that connects the E-stop point to GND and enables the machine to operate. once it's pushed - it opens and disconnect the GND and disables the machine. is it the same here?
    Attached - picture of the board.
    Thanx for your help.
    Jul 2018
    4888
    Re: Looking for help with TB6560 stepper motor driver.
    Hi Amron - no picture - Pter
    Apr 2007
    11
    Quote Originally Posted by peteeng View Post
    You're right, sorry. here it is (I hope...)
    Apr 2022
    58
    It’s programmable in Mach3/4 software. You can use NC or NO switches, most people prefer NC.
    It’s whatever hardware you use.
    Community Moderator RaderSidetrack's Avatar
    Apr 2018
    61
    Some information about a similar board here:
    https://reprap.org/wiki/4_Axis_TB656...ard_Controller
    Note they are not exactly the same, but it may still be useful as they seem to share much of the design.
    Apr 2007
    11
    Quote Originally Posted by Vlod View Post
    Do you know where I can find information how to (to which points) connect the E-stop and the limit switches? my search on the web yield various versions. on some it says that they should be connected to the DB15 port while others - to the DB25 port. RaderSidetrack was kind to post a link to a 4 axis version, which I believe is also different from the 3 axis board that I have. as I mentioned, I never dealt with it before and I really don't wish to cause damage by creating shortcircuits.
    Dec 2012
    198
    Attached you will find the manual that I found. It looks that the small four pin connector is the one you are looking for.
    You have to configure it in the software
    Apr 2007
    11
    Thanx. I'll look into it.
