541,041 active members*
3,831 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > Looking for Mounting Brackets for Dewalt 618 on an Ooznest CNC Workbee.
    Mar 2017
    8
    Question Looking for Mounting Brackets for Dewalt 618 on an Ooznest CNC Workbee.
    Hello all,
    I would like a quote for 2x mounting brackets for a Dewalt 618 using the Workbee mounting dimensions as a guide.
    Overall Width - 120mm
    Thickness - 20mm
    Depth - 120mm
    Cutout Diameter - 88mm
    I've attached Solidworks files for the bracket for your reference. All holes need to be threaded with M5 patterns, except for the countersunk portion of the holes for the mounting bolts 2x.
    Mar 2017
    8
    Re: Looking for Mounting Brackets for Dewalt 618 on an Ooznest CNC Workbee.
    Purchased from outside the site
    Banned
    Dec 2019
    53
    Does anyone know where I can buy or if there is an .stl I can print for a DeWalt DW660 for the Workbee? The original plan was am MPCNC, but after some deeper research the design will not meet my goals of hardwoods. I already have the spindle and would like to use it. I saw a metal on eBay, but it only mounted in one spot vs a top and bottom bracket/mount.
    Speed Test
  1. Workbee Spindle Size
    By fredr in forum DIY CNC Router Table Machines
    Last Post: 03-22-2020, 11:53 AM
  2. Flutes for cutting aluminum on workbee
    By BillyVandory in forum CNC "do-it-yourself"
    Last Post: 08-14-2019, 03:49 PM
  3. OpenBuilds Workbee VS Raw CNC 1.5 VS something else?
    By chugchug in forum DIY CNC Router Table Machines
    Last Post: 02-09-2019, 09:51 AM
  4. RFQ, Small job, mounting brackets
    By sswitaj in forum Employment Opportunity
    Last Post: 03-30-2009, 11:53 PM
