543,717 active members*
2,363 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Looking for right CNC knife machine for cutting thick paper chipboard
Results 1 to 5 of 5
    Jun 2021
    3
    I need to buy a CNC machine cut up to 4mm thick paper chipboard into various shapes. Need this to make prototypes out of thick chipboard.
    I've never worked with CNC machines before. Want to use knife cutting only.
    Any clarification or information would be most appreciated.
    Gold Member
    Apr 2004
    5330
    Re: Looking for right CNC knife machine for cutting thick paper chipboard
    So you don't need the CNC machine to actually cut the thick chipboard and make your prototypes? That's where a CNC router would come in handy. 4mm is a bit thick for a drag-knife cutter, even if it was cardboard and not chipboard. Have you looked into laser cutters?
    Andrew Werby
    Website
    hi ,
    Check working video link as bellows:
    paper size ?
    cutting paper chipboard for package ?
    Oscillating Cutting knife roller for hard paper board
    https://youtu.be/H81O2gET-AI
    https://youtu.be/9LiJ_8YUPK0
    https://youtu.be/ueAcfAwI2Vc
    Jun 2021
    3
    Thanks for your reply. Yes we've used routers. They tore up the board. We've used knife cutters for the board. I think they had to cut twice to get through. The designs we're cutting are pretty detailed as well. Laser cutters burnt the board.
    Jun 2021
    3
    Thanks for your reply!! The bed would be about 24 x 24", or 36 x 36" so small. So would an oscillating cutter be better than a drag knife for cutting thick 4mm board?
  1. Replies: 0
    Last Post: 02-27-2020, 10:26 AM
  2. Buying machine for cutting paper - need advice
    By kodsnoba in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 04-22-2016, 07:55 PM
  3. Plasma cutting machine for cutting Thick sheets
    By aaronhernandez in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-14-2016, 01:38 PM
  4. Multifunction machine 2030s with EOT-2 and TCT-1 CNC Router for cutting paper
    By Alice-sinomac07 in forum Commercial CNC Wood Routers
    Last Post: 02-14-2015, 02:13 AM
  5. Laser cutting machine for paper
    By Sarah-Megan in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 07-27-2012, 04:34 AM
