587,272 active members*
4,440 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Looking for Syil X4 standard, mach3 config xml.
Results 1 to 7 of 7
    Jan 2021
    8
    Hello, I just acquired a 2012 Syil X4 standard with 4th axis and automatic oiler. I am looking for a Mach3 config that's up to date-and working with my machine.
    It's unfortunate that Syil doesn't support the x4 anymore, it really isn't that old in machine years.
    Apr 2024
    13
    Re: Looking for Syil X4 standard, mach3 config xml.
    I need one of these too if anyone comes across it? Can get everything working except for the spindle from software. Otherwise have to manually turn spindle on select direction and set RPM before running code then manually turn it off when done. Is annoying
    Nov 2013
    26
    here's the one I was using and a new one from SYil
    https://1drv.ms/f/s!AjsCINWqzm7ChaAQ...2Cp1g?e=3Mkxhs
    Nov 2013
    4493
    do you not think it worthwhile to update from a parallel port? They were ALWAYS a bit quirky even back when parallel ports were common....but it worse now that they are not common.
    There are any number of parallel port driver boards out there, but only a few that strictly adhere to the original IEEE spec and ONLY those will work.
    Craig
    May 2024
    9
    Hi Craig,
    You're absolutely right. Parallel ports were indeed quirky back in their heyday, and the situation hasn't improved with their obsolescence. Updating from a parallel port to a more modern interface is definitely worthwhile
    Jun 2007
    3734
    Quote Originally Posted by bravernoe View Post
    Hi Craig,
    Easy. Stay offline and use Windows XP!!
    Windows 7: Get into the scheduler and turn off all of the crap.
    Nov 2013
    4493
    yep and rub two sticks together to start a fire...
    Craig
    Nov 2013
    26
    Desktop has windows 7, but the machine is air gapped...
    I got the machine working. I had accidently plugged the Z limit switch cable to the wrong plug.
    Now however, the spindle is making more noise than I remember and the speed occasionally goes very high and then back down again.
    Bad connections on encoder feed?
    Should actual RPMs appear on the Mach3 control panel?
    How tight should drive belt be? It is a ribbed belt, and I didn't go crazy on the tightness, but maybe it should be looser?
    These 120v spindle drive boards are no longer available.
    Are there any good ways to replace the spindle control board, while still using the 5 axis board and axis drivers?
    Any reasonable options to replace 1100w spindle motor?
    Thank you,
    Bryan
  1. Mach3 XML file for Syil X6 inches
    By Fernanocado in forum Mach Software (ArtSoft software)
    Last Post: 10-04-2019, 09:50 AM
  2. NM-145- need config file (XML?)
    By steveb946 in forum Novakon
    Last Post: 10-06-2016, 08:20 PM
  3. Standard ebay controller xml file
    By jimbo12d in forum Mach Wizards, Macros, & Addons
    Last Post: 10-24-2011, 02:51 PM
  4. Replies: 2
    Last Post: 07-19-2011, 05:18 AM
  5. SX3 - Mach3 - non standard pin config - no movement...
    By krazatchu in forum Mach Software (ArtSoft software)
    Last Post: 11-24-2007, 05:45 AM
