567,245 active members*
4,441 visitors online*
    M12 milling a torx's drive
    Hello, trying to mill the outside profile of a T6 torx's drive with a 0.6mm endmill.
    Having trouble this is what i've tried but i seem to just get flats from this path
    Done it with G12.1
    And plane selection G17
    Any ideas
    N431(T6-PROFILE-TORX-SUB)
    G1X1.15C0F150(1)
    G4U0.2
    G2X0.744C0.429R0.43(2)
    G4U0.2
    G2X0C0.859R0.43(3)
    G4U0.2
    G2X-0.744C0.429R0.43(4)
    G4U0.2
    G2C-0.429R0.43(5)
    G4U0.2
    G2X0.0C-0.859R0.43(6)
    G4U0.2
    G2X0.744C-0.429R0.43(7)
    G4U0.2
    G2X1.15C0R0.43(8)
    G4U0.2
    G1G40X5.0C0
    M99
    Jan 2013
    111
    Re: M12 milling a torx's drive
    Why not just use a rotary broach?
  1. alphacam face milling m12
    By basswakr in forum Alphacam
    Last Post: 11-28-2018, 09:10 PM
  2. broaching torx t8 on a haas help.
    By jz25180 in forum General MetalWork Discussion
    Last Post: 09-29-2012, 07:34 PM
  3. 6-48 torx screw
    By RossWalker in forum Want To Buy...Need help!
    Last Post: 07-31-2012, 06:48 PM
  4. core drill for Torx
    By dreherking in forum CNC Tooling
    Last Post: 09-21-2011, 07:15 PM
  5. Taper Head Shoulder Torx Cap Screw
    By Smackre in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 11-20-2006, 07:18 PM
