534,927 active members*
2,903 visitors online*
Results 1 to 4 of 4
    May 2017
    4
    M19 Spindle direction
    Is there a way to change which direction the spindle spins when it orientates? Currently it spins in reverse(mo4). FANUC 31i- Model B it's a live tooling OM VTL
    Nov 2009
    18
    Re: M19 Spindle direction
    Maybe it can be changed in parameter 3706 If you change bit #5 (ORM). The value can be 0 or 1.
    But what do you gain from having it going M3 instead?
    May 2017
    4
    Quote Originally Posted by Prayer View Post
    To run boring heads that I can stop and orientate without spinning the insert backwards.
    Nov 2009
    18
    Im sorry, did't read your question to end. Assumed it was a lathe.
    Have you read this http://www.helmancnc.com/fanuc-g76-f...ycle-cnc-mill/
    Dont know if it can be any help.
    Gl
  1. Spindle Bearing Direction.
    By Blakea1790 in forum Novakon
    Last Post: 07-11-2013, 11:19 PM
  2. Need Help, spindle direction
    Last Post: 07-04-2013, 05:32 PM
  3. Fan direction spindle
    By Flemming in forum Haas Mills
    Last Post: 10-31-2012, 05:17 PM
  4. cw/ccw spindle direction
    By jamessiffel in forum Okuma
    Last Post: 06-13-2011, 01:14 PM
  5. Spindle direction
    By deji in forum Haas Mills
    Last Post: 02-23-2007, 06:53 PM
