Hello everyone,
Working on an automation project, I wrote a simple call program in the CNC_MEM using M198 to call another program from the Data Server.
I'm working on a Fanuc 31i Model B5
When I try to run it, I always get the PS1079 Error "Program File not Found"
- The I/O Channel is set to 5 (#20 = 5)
- Parameter #3030 is set to 0
- Parameter #3233.1 is set to 0
- Parameter #3404.2 is set to 0
- The Data Server is used in FTP mode meaning that I transfer the subprogram using an Ethernet connection to it
Is it possible to have such process (FTP mode and call from the DS in FTP mode) ?
Do you have any clues to solve this issue ?
Regards,
Damien
