554,066 active members*
3,704 visitors online*
Results 1 to 1 of 1
    Jul 2007
    19
    Exclamation M41 SPINDLE MALFUNCTION 1
    Please help me
    i work with a mazak vtc 20 b and when i try to start spindle it show me a alarm "M41 SPINDLE MALFUNCTION 1 "
    the spindle drive show it "F4 32"
    The machine opening normal and it going to home position normally the problem occurs when i try to start spindle
    if anyone can help me i would appreciate it
    Jul 2007
    19
    Re: M41 SPINDLE MALFUNCTION 1
    I found that when I open the machine, the axes go to the home point. So far everything is normal.
    when I turn the spindle by hand on my screen it shows revolutions per 8 for example 8 then 16 then 24 then 32 then 41 then 49 and this continues as I increase the revolutions by hand .
    Maybe this shows you where the problem is ?
