567,778 active members*
2,523 visitors online*
Results 1 to 5 of 5
    Jul 2011
    4
    Mach 3 + RnR Usb Board - No spindle rpm
    Hello,
    Im trying to add hall sensor to read spindle rpm. I do see Index window blink as I rotate spindle(port 3 input 4). But I cant get it to show rpm. Debounce set, relays output set, feedback in sync mode set. I send M3 command ("turn on spindle"), but still no effect.
    So I see reaction on spindle rotation,but for some reason ,it doesnt calc RPM.
    And advice, please?
    Community Moderator
    Mar 2003
    35531
    Re: Mach 3 + RnR Usb Board - No spindle rpm
    Most Chinese boards only support a small number of Mach3 functions, so most likely, your board (or the plugin) does not support it.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2011
    4
    Quote Originally Posted by Sazabi View Post
    Hello,
    And advice, please?
    Yes, but as I mentioned, I do see input on index port. I just missing something in mach3 setup to make it forward that data to rpm.
    Jun 2010
    4200
    It may be that the response time of the Hall senor is far too slow? Rotate by hand: Ok, but spin: no joy.
    Cheers
    Roger
    Jul 2011
    4
    Hello,
    And advice, please?
    Nope, no difference.
  1. Mach3+RNR USB controller+ diy handwheel problem
    By Sazabi in forum Mach Software (ArtSoft software)
    Last Post: 02-03-2023, 08:04 PM
  2. USBCNC RnR Motion USB Controller/Mach3 Setup with Sculpfun 5W laser
    By smanzer in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 05-17-2022, 12:11 AM
  3. Datasheet for USB Breakboard CNC 4 Axis (RnR Eco Motion 2.0)
    By cebaldocchi in forum General CNC Machine Related Electronics
    Last Post: 05-13-2020, 09:16 PM
  4. Mach3 USB Rnr motion control mpg connection
    By CrazyJane in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-13-2018, 01:21 PM
  5. Mach not accepting Spindle RPM
    By Thomasn in forum Mach Mill
    Last Post: 03-12-2013, 01:10 AM
