585,925 active members*
3,363 visitors online*
    Nov 2012
    1267
    Mach3 jog speed
    I have a Mach3 mill with different motors on each axis. X and Y have the maximum speed of 5000mm/min, while Z can only do 1500mm/min.
    Problem is, the jog speed in Mach3 is set as a percentage of the maximum speed for each axis. If I set the desired speed for the X/Y, then my Z axis jogs too slow. If I set a reasonable speed for the Z axis, then the X/Y movement becomes too fast.
    Is there any way to adjust the jog speed for each axis independently?
    Dec 2009
    166
    Re: Mach3 jog speed
    If you set the speed you want for the xy axis to say 50% then when you jog Z you should be able to press shift+Z jog key to jog at max on Z just a thought.
    Nov 2012
    1267
    Re: Mach3 jog speed
    Quote Originally Posted by squirrel_41 View Post
    Unfortunately, the keypad I use for jogging does not have a shift key. But thanks for the food for thought, maybe I can make a key macro or something.
  1. Replies: 0
    Last Post: 11-24-2018, 07:16 PM
  2. Mach3 - Homing speed much much slower than jog speed
    By SouthPark in forum Mach Software (ArtSoft software)
    Last Post: 01-23-2017, 04:46 PM
  3. Replies: 1
    Last Post: 08-02-2013, 10:07 PM
  4. Mach3 and speed
    By jsearles in forum Mach Software (ArtSoft software)
    Last Post: 11-08-2012, 03:04 PM
  5. Spindle speed & Mach3
    By Countryman in forum Mach Wizards, Macros, & Addons
    Last Post: 05-25-2009, 02:53 PM
