592,217 active members*
4,353 visitors online*
    Jul 2024
    4
    Unhappy Mach3 USB red board, random stops and missteps
    Hi, i have the latest version of mach3 and i am using the RNR motion card, the red board.
    Some days i run a program with no problem, and sometimes i get these random stops, the mill stops for a second and continues with no loss in position, and i believe the LEDs in mach software still flashes and the graphic display showing tool tip stops meaning the pc hasnt frozen, and sometimes the motors just missteps and ruin the part, the misstep might even happen when im measuring tool lenght... i get this even with spindle disconnected,
    Pc is a 2nd gen i3 with 8 GB of ram, w10 64 bits
    used 2 cables, still the same. pc runs off another power strip, seperate from the mill.im at a loss. can someone help?
    Apr 2004
    5813
    Re: Mach3 USB red board, random stops and missteps
    Is the PC optimized for Mach3 - all extraneous calls on the processor eliminated? This sounds like what happens if you haven't disabled Windows Update. Mach3 XP optimization.txt steps. - Knowledgebase / Mach3 - Newfangled Solutions Helpdesk
    Andrew Werby
    Website
  1. Mach3 USB Control Board, no communication to outputs
    By Rschaeffer83 in forum Controller & Computer Solutions
    Last Post: 06-01-2024, 02:16 PM
  2. Mach3 USB Control Board?
    By cubby in forum Machines running Mach Software
    Last Post: 09-13-2021, 04:04 PM
  3. USB BREAKOUT BOARD FOR MACH3
    By JACKY2014 in forum USB, RS232, PARALLEL etc
    Last Post: 07-27-2015, 12:44 AM
  4. Random e-stops killing me
    By EvilSpeeder in forum Gecko Drives
    Last Post: 01-23-2015, 03:20 PM
  5. Mach3, USB Key Board, CM-111
    By Robiz in forum News Announcements
    Last Post: 10-08-2013, 06:55 AM
