562,490 active members*
3,755 visitors online*
Results 1 to 6 of 6
    Dec 2014
    62
    mach3 wizard for to adjust gcode to work piece
    hello all,
    i am looking for a tool to change the gcode to the actual position of your workpiece on the machine table.
    lets say you have an irregular shaped piece on your vacuum table with two points that would define the location. lets say you have a star and if you probe two ends of the star rays you would know the position.
    now i am looking for a tool that would change the gcode, the x and y values, to fit the actual position of the work piece. so you probe two points and the gcode is changed.
    i think i read somewhere a while ago about such a tool but i cannot find it.
    does anybody know?
    thanks,
    michael
    Apr 2003
    302
    Re: mach3 wizard for to adjust gcode to work piece
    According to Dan Fritz explain coordinate rotation & scaling?
    Axis scaling (G51, G50) and axis rotation (G68, G69) are options that not very many people use, but they are helpful in some situations.
    The scaling option expands or shrinks all the points around a "center point". You can scale one axis at a time, or you can scale multiple axes if you want. It's useful for compensating for a shrinkage factor, or for making non-circular arcs. For example, if you program your machine to mill a square pocket, you can set the scale center point to the center of the pocket, scale X to say, 90%, and you'll cut a rectangular pocket with the X dimensions shrunk by 10%. If the center point you specify isn't in the center of the pocket, the pocket will be scaled in X like before, but it will also "shift" in the X axis also.
    Rotation is similar. All the points in your program will be rotated around a center point by the angle you specify. Rotation is nice if you have a fixture that's not quite lined up with an axis, and you want to avoid using an indicator it to make it straight. Some machines like Monarch use a probing routine to check the fixture and compensate with a wee bit of rotation automatically.
    I've used rotation to mill the profile of a large 50-tooth gear by programming one tooth of the gear in a subroutine, then calling the sub 50 times with an angular rotation each time. I used some macro statements to calculate each angle for the G51 command.
    ... Just be sure to cancel these functions after you use them!
    Some other tips
    Do G68/69 coordinate rotation. Scaling before rotation.
    You must scale XY then Z
    Oct 2005
    1120
    If you simply want to move a part around on the table Use one of these to offset the Point of origin X0,Y0
    G52
    G92
    G54-259 fixture offsets
    Just a thought, (;-) TP
    Dec 2014
    62
    thanks kdoney,
    i think the g68 is what i am looking for.
    i thought of writing a macro but i dont have much experience with it. so here is what i thought:
    first in your cad software you take one point on your model and define that as zero point.
    then take a second point, measure the x and y difference, and the distance. the distance will later be the radius.
    on your machine toggle to the first point and zero axis.
    enter the x and y difference and move the machine to that point.
    unlikely the machine will be exactly over the second point so you would now toggle on a circle arround the zero point where the radius is the distance between point 1 and 2.
    if youre above the second point you can see how many degrees you had to toggle and use that for the g68.
    would that work or does anybody have a better idea?
    thanks,
    michael
    Nov 2022
    12
    i am looking for a tool to change the gcode coles petrol station near me
    Jun 2022
    Unfortunately, although I really want to help you, I have not found what you are looking for. I will keep looking to help you.
    stickman fighter
  1. LOGOS TO GCODE THAT WORK WITH MACH3
    By macatoms in forum OpenSource Software
    Last Post: 05-25-2012, 08:55 AM
  2. Mach3 showing wrong side of work piece?
    By FL Ray in forum Machines running Mach Software
    Last Post: 04-02-2012, 04:56 PM
  3. Why does my Gcode not work? Bobcad to Mach3
    By jrslick22 in forum Screen Layouts, Post Processors & Misc
    Last Post: 12-13-2010, 09:38 AM
  4. how to adjust the pulse frequency on mach3
    By thesaent14 in forum Mach Mill
    Last Post: 03-20-2007, 02:18 AM
  5. Nesting Wizard, Mach3 internal wizard.
    By thuffner3 in forum Mach Software (ArtSoft software)
    Last Post: 03-05-2007, 03:38 AM
