545,781 active members*
1,835 visitors online*
Results 1 to 4 of 4
    Aug 2018
    26
    Mach4 jog question
    Mach 4 hobby on cobbled together learners setup.
    To jog my spindle I have to click on the jog tab then use the mouse to click on the appropriate axis button. My arrow keys don't do anything.
    When setting up my gantry on Mach3 I could hit the tab key the move the spindle with the arrow keys and would like something similar in Mach4.
    Then while watching the university of youtube, I saw an operator jogging Mach4 with the arrow key.... what am I missing?
    Thanks in advance to all who contrib
    cncneon
    Nov 2013
    1220
    Re: Mach4 jog question
    yes Mach4 can do the same thing.....but its more involved to set up.
    You have to set up the keys you want to use in the Keyboard plugin, and then attach those key inputs to the jog signals of Mach4.
    This procedure is very flexible, for instance you can have one set of keys for slow speed touch offs, and another set for high speed traverses,
    or maybe use a modifier key like ALT to determine the jog speed. The only drawback is that you have to set it up....and that can be a bit confusing
    to start with. Mach3 had this functionality built in....but it could not readily be changed, whereas it can be with Mcah4.
    May I suggest posting on the Mach4 Gen Discussion board.
    Craig
    Nov 2013
    1220
    just had another thought....have you <Enabled Keyboard Input>? (on the Jogging tab).
    Craig
    Aug 2018
    26
    Looks like the keyboard plugin is going to be the answer. On the jog tab I do have a green button that reads "enable keyboard input" or something similar but clicking on it does nothing.
    I haven't had time to try the keyboard plugin but wanted to thank you for the answer.
    cncneon
  1. Newb question about microstepping. LMS 3990 mill. Mach4
    By t3kboi in forum Benchtop Machines
    Last Post: 05-31-2019, 11:00 PM
  2. Mach4 Help Needed: Potentially Paid Mach4 & CNC Consulting
    By rappinadam in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2018, 06:49 PM
  3. Jog shuttle - question
    By RA-Bowtie in forum Tormach Personal CNC Mill
    Last Post: 04-08-2015, 12:19 AM
  4. Jog question
    By tinman13 in forum Mach Software (ArtSoft software)
    Last Post: 02-12-2010, 03:17 AM
  5. Not sure if this is a Mach4 question or G-Rex
    By srbliss in forum Mach Software (ArtSoft software)
    Last Post: 03-14-2006, 01:33 PM
