562,487 active members*
3,674 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Mach4 not travelling the full Y axis
    May 2022
    Hi All,
    We are using a home built CNC mill running on Mach4. When we cut circles, we noticed flats on the top and bottom of the holes (see attached pictures). We measured the backlash of our machine and it was not significant. We tried different Gcode generators and got the same result. After that, we cut a square with the corners facing in the X and Y directions. After inspecting the square, we found that the corners pointing in the Y axis directions were flat instead of pointed and the Y axis diagonal is 0.015" shorter than the X axis. It seems to us that for some reason the controller is not directing the machine to travel the full Y distance. Has anyone seen this issue/ know if there is a setting that could fix this?
    Thanks,
    Josh
    Nov 2013
    2198
    Re: Mach4 not travelling the full Y axis
    if its not backlash then it is machine flexure....they have a similar effect.
    I've used Mach4 for many years and I expect a circularly interpolated hole to be within 0.02mm (0.0008 in) of round. Even then I would expect that the majority of the 0.02mm
    out-of-round, say 0.015mm, would be the flexure of the 1.5mm and 3mm tools that I commonly use.
    Craig
    May 2022
    Thsnks for responding! I am reluctant to say it is flexure as we still see the same problem when we lower the feed rate and reduce the force on the tool.
  1. Mach4 5 Axis Saw profile
    By Orbnotacus in forum Mach 4
    Last Post: 12-29-2021, 09:52 AM
  2. Mach4 Help Needed: Potentially Paid Mach4 & CNC Consulting
    By rappinadam in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2018, 06:49 PM
  3. X axis over travelling during run.
    By JayCop in forum DIY CNC Router Table Machines
    Last Post: 04-25-2012, 01:26 AM
  4. The Widgitmaster's Travelling CNC Medicine Show
    By BobWarfield in forum DIY CNC Router Table Machines
    Last Post: 03-25-2007, 05:38 AM
  5. travelling salesman
    By ghyman in forum Visual Basic
    Last Post: 10-27-2005, 11:16 AM
