547,049 active members*
2,409 visitors online*
    Exclamation Machine axis not ready
    Hi all
    I have a doosan VM960L with a Fanuc control 31i
    when i put in jog type and press the keys (for example X+ ) all the value (abs. relative machine) work normally. For example when press positive key value goes up and press negative keys values goes down but any of the axis didn`t move.
    When i see the cabinet i understand that all of my drives are in "not ready" state
    i have not any erors o alarms in messages tab.
    what should i do !?
    Thanks all
    Aug 2019
    50
    Re: Machine axis not ready
    Please clarify some details.
    -In the current state when you jog an axis the position display updates but the axis do not mechanically move. And if you move a large amount you do not get excess error alarms.
    If the above is true.
    -On the FSSB screen under System is there any indication of trouble? Are all drives / axis displayed normally.
    -On the status bar of the display you do not see a "--EMG--" or "-RESET-"
    -You have "-" on the axis (not spindle) drives vs "0" which indicates not ready
    -Has anyone had cause to change parameters?
    -Is there per chance a MLK or Machine Lock switch on the operators panel that has been turned on?
    -There are no indictors next to the axis names on the position display screed "D", "I", "S".
  1. New machine almost ready but questions?!
    By Nitrografix in forum DIY CNC Router Table Machines
    Last Post: 06-25-2013, 11:45 AM
  2. Who all make Ready to Go 4 Axis Controllers
    By gunlocators in forum DIY CNC Router Table Machines
    Last Post: 02-21-2009, 02:13 PM
  3. Axis R ready to rock!
    By Steve Crum in forum Linear and Rotary Motion
    Last Post: 08-21-2008, 05:33 AM
  4. #05 Axis regulator not ready
    By speeeeed in forum Fanuc
    Last Post: 12-13-2007, 11:05 PM
  5. Cnc Ready 3 In 1 Machine
    By fastlanecafe in forum News Announcements
    Last Post: 07-21-2006, 07:17 PM
