Hello Guys,
Lately i have been facing a problem with the 5 - Axis machine that I am working on. The rotation of C - Axis stops at a particular code.
For Example:
N220 X0.267 Y-19.998 Z49.809 C0.7653
N225 C0.7636........................................... ................................[MACHINE HALTS AT THIS CODE, I CLICK STOP AND THEN START THE CYCLE FROM THIS LINE]
N230 X0.134 Y-20 Z49.866 C0.3826
N235 X0.133 C0.3809
N240 X-0.001 Z49.885 C-0.0017
N245 C-0.0035............................................ .............................[WORKS PERFECTLY]
N250 X-0.135 Z49.865 C-0.3861
N255 C-0.3878................................... ..................................... [MACHINE HALTS AT THIS CODE AGAIN, I CLICK STOP AND THEN START THE CYCLE FROM THIS LINE]
SO ON
When i simulate the same G-Codes in K-MotionCNC it work fine without any pause. I tried to run the same G-Codes on the machine multiple times and each time it stops at that exact line.
Has anyone faced a similar problem with their machine.
Your suggestions on this topic will be helpful to overcome the hurdle.
Thank you in advance
Vignesh M
