556,693 active members*
1,610 visitors online*
Results 1 to 5 of 5
    May 2021
    machine looses position in X axes
    hi i am new to this forum
    was hoping to get some help with my older MS CNC JR vertical milling machine
    the machine loses tracking ever so often in the x axes
    totally random so is the amount of of position loss
    the amount is anywhere from .002 to .0049"
    it usually happens on the beginning of the milling cycle or end never in the process
    any help would be greatly appreciated
    DS
    May 2022
    17
    Re: machine looses position in X axes
    The first thing that comes to my mind is that the milling cutter may fixed wrong (garbage in the collet). Are there options set correctly (measure whether the real movement coincides with the program one)? If it's has broken down, then perhaps there are problems of mechanics.
    Apr 2004
    5517
    It sounds like lost steps, which happens when steppers try to go too hard or too fast. You might try turning down the acceleration on the axis that's failing. It could be due to a lubrication failure, or it could be a coupler that's slipping.
    Andrew Werby
    Website
    May 2022
    9
    try to reduce the speed of the stepper motor.
    May 2022
    17
    Yes, you're right! It could work.
    Dec 2021
    32
    We produce DRO and linear scale, maybe it will help you, you can go to https://www.amazon.com/stores/HHXXOV...2?ref_=ast_bln
    view on
    Or on Whats: +8613528773691
    Contact me at szhxx2019@163.com, marchleon13528773691@gmail.com
  1. Replies: 7
    Last Post: 08-04-2014, 11:21 PM
  2. Machine always looses position when I press Escape to stop motion is there a fix?
    By Smertrios in forum Mach Software (ArtSoft software)
    Last Post: 06-05-2013, 10:26 PM
  3. tmc 1000 looses position.
    By barthmv in forum Benchtop Machines
    Last Post: 07-11-2012, 02:37 AM
  4. Toolchanger looses position
    By mniadna in forum Haas Mills
    Last Post: 05-19-2010, 11:26 PM
  5. z axis looses position - like it jumps time
    By jgriffith66 in forum Centroid CNC Control Products
    Last Post: 03-02-2009, 06:23 AM
