585,764 active members*
4,571 visitors online*
Results 1 to 10 of 10
    Feb 2011
    138
    machine-measure-?
    Question: is the lines under machine/measure/"Edge ..... and Probe calib." exluded from (language)*.txt file purposefully ?
    I am using fast buttons in "Bottom btn" but could not add this new ones...
    Mar 2017
    1304
    Re: machine-measure-?
    You don't need language file to create button files.
    If you just need command name then you can type "=cmdlist()" into MDI and you'll get full list in output window
    Nov 2015
    260
    Is it intended that the machine no longer moves to the measured position after measuring. Unfortunately no documentation on this.
    Mar 2017
    1304
    Yes, this is by design.
    All unwanted moves were removed from measuring routines. No more dangerous travels to safe height. And compatibility with CAM postprocesors.
    Feb 2011
    138
    Ok, I'll try, but still would like to convert to my native language
    Nov 2015
    260
    Quote Originally Posted by PlanetCNC View Post
    What do I have to enter where so that it moves to the position that was measured after measuring.
    As it is now, it's totally impractical for me and it destroys my entire workflow.
    Mar 2017
    1304
    1. You can add those moves to script.
    2. You can use old scripts. I'll post updated old scripts in few days, along with some small fixes in software..
    3. You can get used to new much more practical scripts.
    Feb 2011
    138
    sucsess! made all butons I need :wave:
    Aug 2020
    131
    The main problem with the new scripts is that its impossible to null the axis if you use a touchscreen.
    The Axis needs to be at the null position for this.
    Mar 2017
    1304
    New version sets:
    $<cmd_setworkoffset> and
    $<cmd_setcsoffset>
    variables. You can edit measure scripts and add them after G65 code in measure scripts.
  1. Measure
    By mar_cone in forum PlanetCNC
    Last Post: 12-04-2019, 10:48 PM
  2. Measure
    By Eatonbrayer in forum PlanetCNC
    Last Post: 06-16-2017, 07:45 AM
  3. 3D measure
    By Chriese in forum Okuma
    Last Post: 01-09-2010, 01:43 PM
  4. z0 measure
    By albert.B in forum Fanuc
    Last Post: 08-29-2008, 01:14 PM
  5. Need measure
    By titoniks in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2006, 07:27 PM
