535,449 active members*
3,103 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > machine requirements for universal gcode sender
    Mar 2011
    324
    I had this old laptop running UGS for my DIY cnc router. Was working good but now I think the video card crapped out as it will not send video to its display or a connected display. So, what are your experiences with what UGS needs to run well?
    I have a separate computer that I do my CAD and CAM on so all it needs to run is UGS and the GRBL IDE and of course JAVA and netbeans.
    Mar 2011
    324
    Re: machine requirements for universal gcode sender
    Can I use a chromebook?
    Jan 2021
    5
    It requires a good laptop with a good graphics card. If you are on a budget, and can't spend big, and still want to buy a good laptop with the graphics card, Acer Nitro is a good option. It houses a GTX 16-Series graphics that let you handle visually loaded tasks quite seamlessly.
  1. 3018 cnc universal gcode sender
    By Qbubbawm4mm in forum OpenSource Software
    Last Post: 10-29-2020, 05:15 PM
  2. Replies: 4
    Last Post: 03-27-2019, 11:19 PM
  3. Help with Universal Gcode Sender
    By rfresh737 in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 01-27-2016, 12:17 AM
  4. Universal Gcode Sender Z Axis Help
    By rfresh737 in forum Arduino
    Last Post: 01-26-2016, 06:46 PM
  5. Universal Gcode Sender Z Axis
    Last Post: 01-26-2016, 05:10 PM
