Hello Guys,
I have a Chinese laser cutter machine which has a strange fault. There is a control panel on the machine where I can launch the XY move, exhaust fan, air compressor and the laser power supply.
There is a "Test" button too for testing the laser beam.
I switch on the devices one by one, works everything well. But as soon as the machine starts the cutting or I push the Test button for shotting with the laser, some or all of the equipments (fan, airblow, etc) stop.
Then I switch them on again, push the Test button again, and the devices shut down again.
I have to do this 2-3 times and then everything works well. After that I can use the machine for hours without any problem. But the problem is come back every daily "first" starting.
I have made a short video about the problem:
Do you have any idea what the problem might be?
