585,735 active members*
4,951 visitors online*
IndustryArena Forum: Machinist Hangout
Page 34 of 37 243233343536
Threads 661 to 680 of 721
Machinist Talk Hangout- let's talk!
  1. anodizer screw up
    Started by FUBAR62172, 04-03-2015 07:39 PM
    black, cash, customer, embrace, make
    04-03-2015, 09:00 PM Go to last post
  2. Not sure what to do
    Started by Espie, 04-03-2015 01:22 PM
    cnc, router, sounds, surface, table
    04-03-2015, 01:22 PM Go to last post
  3. hard anodizing question
    Started by FUBAR62172, 03-24-2015 10:09 PM
    black, customer, glossier, hard, oversize
    03-24-2015, 10:58 PM Go to last post
  4. Mach1 mill misses to dril some holes
    Started by mrpeja, 03-22-2015 09:49 AM
    cnc, drill, file, x1.971, y11.6
    03-23-2015, 10:07 AM Go to last post
  5. 2 anti-backlash nuts per axis
    Started by frunple, 03-21-2015 01:22 AM
    anti-backlash, axis, resistance, sides, wondering
    03-23-2015, 07:36 AM Go to last post
  6. Looking for help machining my first CNC part!
    Started by jevs, 03-04-2015 02:22 AM
    03-19-2015, 07:40 PM Go to last post
  7. Angry Aussie newbie needs some help...
    Started by Clivem, 03-14-2015 08:42 AM
    axis, cnc, drive, motor, steppers
    03-17-2015, 02:01 AM Go to last post
  8. Infrared Heat Sensor Question
    Started by kend, 03-16-2015 04:05 AM
    connect, difference, digital, idea, thermocouple
    03-16-2015, 04:05 AM Go to last post
  9. syntec question
    Started by shazoak, 03-14-2015 05:59 PM
    cnc, cut, question, sheet, syntec
    03-14-2015, 05:59 PM Go to last post
  10. VFD
    Started by 1hander, 03-13-2015 07:13 AM
    buy, emerson, ksb1100110, meets, vfd
    03-14-2015, 03:23 PM Go to last post
    03-12-2015, 08:01 PM Go to last post
  11. HELP with program Okuma LC 10 OSP 3000 control
    Started by mikeapalmer, 03-12-2015 07:57 PM
    control, okuma, osp, parts, program
    03-12-2015, 07:57 PM Go to last post
  12. V21 Express no longer able to merge file
    Started by Dif, 03-11-2015 05:31 AM
    cad, express, file, merge, v21
    03-11-2015, 05:31 AM Go to last post
  13. Tooling out a new machine,
    Started by ponderosa_texas, 03-06-2015 06:19 AM
    compatible, machine, mill, set, tools
    03-07-2015, 01:47 AM Go to last post
  14. Long tools(10+ Dia) and calculating speeds/feeds
    Started by cmelo, 03-04-2015 10:19 PM
    03-06-2015, 09:19 AM Go to last post
  15. Mechanical copy / 3d scan question
    Started by jpcnc, 03-05-2015 01:00 PM
    basic, cnc, copy, information, lathe
    03-05-2015, 01:00 PM Go to last post
  16. DeepGroove1 or Grizzly
    Started by tx_pilot, 03-04-2015 11:45 PM
    bobcad, cnc, grizzly, machines, work
    03-04-2015, 11:45 PM Go to last post
  17. Need help!
    Started by Lost-one, 02-12-2015 04:00 PM
    door, drive, floppy, machine, machines, mori, need help, parameters, silly
    02-27-2015, 09:32 PM Go to last post
    02-21-2015, 02:38 AM Go to last post
  18. PPAP documentation advice
    Started by shimmwagen, 02-20-2015 07:58 AM
    documentation, ppap, process, provide, starting
    02-20-2015, 07:58 AM Go to last post
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
