548,317 active members*
1,680 visitors online*
Results 1 to 1 of 1
    Mar 2020
    Macro programming help
    Hi. We have a bunch of Doosan puma lathes with fanuc control. Im a fairly experienced cnc programmer. But macros are very unknown for me. I want an easier way for operators to adjust programs. Im looking to make a simple macro program where u can edit x and z offset. We have alot of similar products with different lenght and dimension. I want to have the option to write in the lenght and diameter at the start of the program. But i have no clue how to do this. So i wonder if anyone could give me an example on how to do this?
    Apr 2011
    789
    Re: Macro programming help
    Look up PROGRAMMABLE PARAMETER ENTRY (G10) in the programming manual for controller that is on your machine.
    Feb 2011
    353
    A couple of books that could help are
    fanuc custom macro b by Sihna
    fanuc cnc custom macro's by Peter Smid
    to have the program make changes to the machining of the part by having the operators change a macro variable
    #1-#33 ARE LOCAL
    #100-#199 ARE COMMON -( POWER OFF RESETS THEM)
    #500-#999 ARE COMMON (STAY ACTIVE DURING POWER OFF)
    O1234
    G00G90G20G40G97G99
    #500=2.000(MATERIAL OD)
    #501=1.900(TURN DIA.)
    #502=-1.000(Z TURN LENGTH)
    N1(TURNING TOOL)
    G28U0.W0.
    G0G97S2000T0101M3
    M8
    G0X[#500+.1]Z.100(MATERIAL DIA.+.100)
    G1Z0.F.005
    G1X-.06
    G0Z.05
    G0X[#501-.05](TURN DIA. -.05)
    G1Z0.F.005
    G1X#500,C.03(TURN DIA WITH CHAMFER.)
    G1Z#502(Z TURN LENGTH)
    G1X#500,C.03(MATERIAL DIA. WITH CHAMFER)
    G1Z[#502-.05](MOVE FOR CHAMFER)
    G0X[#500+.1](CLEARANCE MOVE)
    G0Z-.1
    G28U0.W0.
    M9
    M01
    I would also include some safety's to avoid some crashes if the data is wrong
    IF[#500LT1.75]GOTO9000(SMALLEST OD.)
    IF[#500GT2.500]GOTO9000(LARGEST OD)
    IF[#500LT#501]GOTO9000(TURN DIA LARGER THAN MATERIAL)
    IF[#502GT0.]GOTO9000(Z LENGTH IS POSITIVE)
    N9000( DATA. OUT OF RANGE)
    Feb 2006
    982
    Quote Originally Posted by Ms88 View Post
    Look at RCS60 give you example, it pretty much write one program for a family part and assign movement axis with variables you want.
    The best way to learn is trial error.
