585,948 active members*
3,738 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Magnum400 Drivers - Need Help
    Aug 2007
    55
    I'm working on an old machine that uses the Magnum 400 drive amplifiers and need a bit of help getting it to work.
    Everything works on the drives, I can jog the servos using the "digital speed" setting within "speeder one" as described in "motor test" in the manual page 43.
    Manual found here https://www.axorindustries.com/wp-co....05-15-ENG.pdf also attached to post
    Problem is, when i select the pulse and direction setting and save to eeprom I am unable to get any movement out of the motor or response from the drive.
    I am very sure that the pulse train is coming out of the motion controller, I can enable the drive using the software or input pin but still no movement.
    What am I missing here?
    thanks
    Attached Files Attached Files
    Aug 2007
    55
    Re: Magnum400 Drivers - Need Help
    Found the answer, digital input (DGT-IN1) enables the drive, DGT-IN2 enables motion commands, enable one then the second and away it will go.
    Page 40 of rev.2/02/2005 in the manual
  1. Drivers?
    By bjwx2 in forum Stepper Motors / Drives
    Last Post: 07-09-2018, 02:51 PM
  2. Stepper motor&drivers,servo motors&drivers,motion control card CHINA factory
    By stepmotordriver in forum Manufacture Company Listing
    Last Post: 06-21-2014, 09:14 AM
  3. What drivers should I use with these........
    By MadeInTheShed in forum Stepper Motors / Drives
    Last Post: 07-22-2011, 04:52 AM
  4. IMS drivers vs. Gecko drivers
    By cnczoner in forum Stepper Motors / Drives
    Last Post: 04-05-2010, 04:50 AM
  5. drivers
    By MR MOTION in forum BobCad-Cam
    Last Post: 04-17-2009, 02:51 PM
