585,760 active members*
3,790 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > Maho DMC70V - TSC/IKZ (Through spindle coolant) problem
    Mar 2018
    3
    I have a spindle from Maho DMC70V milling machine. As I found, some of this machines have through spindle cooling system (TSC). I bought spindle with oryginal hydraulic tool clamp. The hydraulic clamp have additional inner but it looks like connector for air blow through spindle in ATC cycle. I need any information about TSC system in this machines. It is possible to add this system to my spindle? I attach the photos of spindle and hydraulic clamp. Maybe someone have service manual for this machine? Thank you in advance.
    Dec 2019
    9
    Re: Maho DMC70V - TSC/IKZ (Through spindle coolant) problem
    do you still have access to this machine ? I am looking for a set of parameters macro's and anything I can get my hands on for the same machine any help would be very helpful
  1. Replies: 0
    Last Post: 05-19-2019, 12:45 AM
  2. Maho MH500C Spindle problem
    By georgetsag in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 07-01-2016, 04:13 PM
  3. Motor spindle DMC70V
    By Potti in forum SERVICE FOR CNC-MACHINES
    Last Post: 05-06-2011, 08:22 AM
  4. Replies: 3
    Last Post: 02-08-2011, 09:07 AM
