548,681 active members*
2,196 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Philips > Maho MH 600E 6406/400, Memory constants?
    May 2013
    Question Maho MH 600E 6406/400, Memory constants?
    Hi People, after a long time I'm trying to get my MAHO MH 600E up and running. Now I'm worried about system memory.
    SW version 6406/400.
    Before I load the constants. so the memory is 20000Kb + -. After loading the constants is 11532kb and that is very little. Don't know what machine constant determines memory redistribution? Or does it turn on BTR mode?
    Thank you in advance
    Quote Originally Posted by pepa4 View Post
    Hello,
    You can set the size of the BTR memory in the parameters. It is usaly a small value. I don t know exactly the number of this parameter but you can check by pressing the CONSTANT MEM button then OPERATOR MC. It should not be more than 30kb.
    Nov 2013
    13
    Quote Originally Posted by viorel23cnc View Post
    Hello,
    Hello Can you tell me what are the parameters on the machine and which program you use and the settings on the program and what is pressed on the machine to do
  1. MAHO 600E
    By swat cat in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-30-2020, 09:55 PM
  2. Maho MH 1600S constants
    By viorel23cnc in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-25-2020, 08:15 PM
  3. Maho mh 600e
    By Selven1 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-12-2018, 07:39 PM
  4. Maho 600E
    By putzer89 in forum SERVICE FOR CNC-MACHINES
    Last Post: 01-31-2011, 10:09 PM
  5. Maho 400E or 600E
    By HKgunslinger in forum Want To Buy...Need help!
    Last Post: 11-10-2008, 02:12 AM
