585,715 active members*
3,718 visitors online*
Page 1 of 2 12
Results 1 to 20 of 25
    Maho Philips 432 answers
    Hello everyone ,
    I am the proud owner of a Maho mh 600 e from 1986 that I use daily in my shop. I am starting this post for those who need info or have questions on this subject
    https://www.youtube.com/user/viorel22cr
    Mar 2016
    22
    thanks for your initiative. do you use any preprocessor and postprocessor for your maho? and how did you get it?
    Re: Maho Philips 432 answers
    Quote Originally Posted by mamech View Post
    Hello , I use EdgeCam. You can get the postprocessor online , or you can build your own post if you have a bit of patience and are familiar with the software and g code. I know GibsCam has a postprocessor for Maho machines but i never used it.
    Mar 2016
    22
    Quote Originally Posted by viorel23cnc View Post
    thanks for you information. actually, The factory that I work with is using solidcam, and sadly, I do not have the sufficient experience in g-code to make a post.
    another question please, we have a big problem in running the DNC of our maho (it is maho 700, but I think that the changes are minor between it and maho 600). may you tell me how do you prepare your machine to run the programs in DNC mode?
    thanks
    thanks
    Hy there are two ways to go about DNC transfer , one is BTR and the other is the normal transfer mode.
    Old Maho machines use BTR mode option from the menu screen to transfer large programs from PC that are to big to be stored in memory, Basically the controller loads and executes a couple of program lines and in the mean time deletes the executed lines and loads others. It works fine, I executed programs as large as 30 000 lines with it. I believe the standard memory size on this machines can permit you to store a program about 4000 to 6000 lines of code. So if you have a smaller program that you need to repeat you can use the normal transfer mode because using BTR mode it's time consuming and requires you to restart the procedure every time you want to execute a program.
    There are a couple of steps before you start to transfer :
    1 make sure your RS232 cable is configured properly
    2 the software that you use to transfer the program to the machine has all the transfer parameters set correctly ,like baud rate , stop bits etc. I recommend you Cimco Edit software for transfer since it also has the ability so generate programs for Maho machine from shapes you draw , great program
    3 now for the code itself there may be some modification you need to do , like in my case the program will not transfer correctly if it starts with : % PM but it will only with %PM
    It should look something like that :
    %PM
    N9001
    N1 G18 T1 M6 or M67 if you don't have a tool changer
    I must mention that to use BTR mode first you must alter a constant from the machine constants. In my case is the BTR macro size constant. You must decrease it's value to about 40 or 90 kb . Normally the value of the constant is too big. Here is the tricky part : if you make the value to small every time you transfer a program it will execute a couple of lines than it will stop the machine in the cut to load new lines. If you make it to big it will overflow the memory and stop the transfer , so be sure to practice a bit before starting to work.
    Regards
    Mar 2016
    22
    thank you very much for the detailed information . Actually we was trying so much with the maho to operate DNC mode, but without any sucess, so let me please ask about some details part by part.
    1)regarding the machine itself, there is parameter 770 that says : DIO/DNC selection (0-5)
    it has values from 0 to 5 . what should this paramter be for activating DNC mode? are there other parameters that needs to be adjusted specially for DNC mode?
    2) after setting the parameters, what I need to press on the machine keyboard to make it waiting the data from my pc?
    thank you very much for you help
    I am away from the shop for 2 weeks so I can't tell you exactly the value for that parameter. I used only the factory settings for the parameters. The only time you need to change the parameters is after the machine has not been turned on for a long time and the parameters memory has been lost.
    Ok so if you want to transfer from the pc to the machine do this : press the MANUAL KEY than press the Prog Mem key then press F5 , You should see a list of programs stored in memory , Now type the number of the program you want to transfer from the pc . it should be a number above 9000 . After you have typed the number pres the Enter key once , now press the Data In out key an finally press F2 for input
    Mar 2016
    22
    thank you for your answer. but why its number must be greater than 9000? we tried to transfer programs in memory (not DNC) and they were numbered 1, 2,3 etc..
    Does this mean, that the program that has number greater than 9000, will be considered a DNC program, not a normal program on machine memory?
    Can u send me a copy of the program you tried to transfer?
    The reason you use a number greater than 9000 is because of a machine constant , I don't know the exact number. This means that all the programs with a number greater than 9000 are interpreted asa external programs DNC , and all others below 9000 are the programs u make directly on the controller _internal programs.
    regards
    Mar 2016
    22
    hello
    sorry for my delayed answer. actually I wanted to try what you told me with the machine first before telling you what happened.
    actually, I found the parameter that accept program number to be >9000 or <9000 , and the result in both cases, is either that the program that I send to be stored in memory normally (not DNC), or I get an error that program number needs be greater than 9000 (this happens when I send program with number 1,2,3 etc..., while the parameter forces the machine to accept programs with number >9000). thi is the test code that I tried:
    Code:
                       %PM5
    N5
    N1 G90
    N2 G40
    N3 G52
    N4 G17
    N5 T18 M6 S1800
    N6
    N7 G0 X-112.7 Y48.2 Z10 M13 F1000
    N8 G0 Z2
    N9 G1 Z0 F800
    N10 G1 X112.7 F1000
    N11 G1 Y0
    N12 G1 X-112.7
    N13 G1 Y-48.2
    N14 G1 X112.7
    N15 G0 Z10
    N16 (F-CONTOUR)
    N17 G0 X69.9 Y-116.4 Z10
    N18  S1200 M13 F1000
    N19 G0 Z2
    N20 G1 Z-5 F1200
    N21 G1 X87.578 Y-98.722 F1000
    N22 G3 X69.9 Y-91.4 R25
    N23 G1 X-69.9
    N24 G2 X-101.4 Y-59.9 R31.5
    N25 G1 Y59.9
    N26 G2 X-69.9 Y91.4 R31.5
    N27 G1 X69.9
    N28 G2 X101.4 Y59.9 R31.5
    N29 G1 Y-59.9
    N30 G2 X69.9 Y-91.4 R31.5
    N31 G1 Y-93.4
    N32 G0 Z10
    N33 G0 Y-116.4
    N34 G0 Z-3
    N35 G1 Z-10 F1200
    N36 G1 X87.578 Y-98.722 F1000
    N37 G3 X69.9 Y-91.4 R25
    N38 G1 X-69.9
    N39 G2 X-101.4 Y-59.9 R31.5
    N40 G1 Y59.9
    N41 G2 X-69.9 Y91.4 R31.5
    N42 G1 X69.9
    N43 G2 X101.4 Y59.9 R31.5
    N44 G1 Y-59.9
    N45 G2 X69.9 Y-91.4 R31.5
    N46 G1 Y-93.4
    N47 G0 Z10
    N48 G0 Y-116.4
    N49 G0 Z-8
    N50 G1 Z-15 F1200
    N51 G1 X87.578 Y-98.722 F1000
    N52 G3 X69.9 Y-91.4 R25
    N53 G1 X-69.9
    N54 G2 X-101.4 Y-59.9 R31.5
    N55 G1 Y59.9
    N56 G2 X-69.9 Y91.4 R31.5
    N57 G1 X69.9
    N58 G2 X101.4 Y59.9 R31.5
    N59 G1 Y-59.9
    N60 G2 X69.9 Y-91.4 R31.5
    N61 G1 Y-93.4
    N62 G0 Z10
    N63 G0 Y-116.4
    N64 G0 Z-13
    N65 G1 Z-20 F1200
    N66 G1 X87.578 Y-98.722 F1000
    N67 G3 X69.9 Y-91.4 R25
    N68 G1 X-69.9
    N69 G2 X-101.4 Y-59.9 R31.5
    N70 G1 Y59.9
    N71 G2 X-69.9 Y91.4 R31.5
    N72 G1 X69.9
    N73 G2 X101.4 Y59.9 R31.5
    N74 G1 Y-59.9
    N75 G2 X69.9 Y-91.4 R31.5
    N76 G1 Y-93.4
    N77 G0 Z10
    N78 G0 Y-116.4
    N79 G0 Z-18
    N80 G1 Z-25 F1200
    N81 G1 X87.578 Y-98.722 F1000
    N82 G3 X69.9 Y-91.4 R25
    N83 G1 X-69.9
    N84 G2 X-101.4 Y-59.9 R31.5
    N85 G1 Y59.9
    N86 G2 X-69.9 Y91.4 R31.5
    N87 G1 X69.9
    N88 G2 X101.4 Y59.9 R31.5
    N89 G1 Y-59.9
    N90 G2 X69.9 Y-91.4 R31.5
    N91 G1 Y-93.4
    N92 G0 Z10
    N93 G0 Y-116.4
    N94 G0 Z-23
    N95 G1 Z-30 F1200
    N96 G1 X87.578 Y-98.722 F1000
    N97 G3 X69.9 Y-91.4 R25
    N98 G1 X-69.9
    N99 G2 X-101.4 Y-59.9 R31.5
    N100 G1 Y59.9
    N101 G2 X-69.9 Y91.4 R31.5
    N102 G1 X69.9
    N103 G2 X101.4 Y59.9 R31.5
    N104 G1 Y-59.9
    N105 G2 X69.9 Y-91.4 R31.5
    N106 G1 Y-93.4
    N107 G0 Z10
    N108 G0 Y-116.4
    N109 G0 Z-28
    N110 G1 Z-35 F1200
    N111 G1 X87.578 Y-98.722 F1000
    N112 G3 X69.9 Y-91.4 R25
    N113 G1 X-69.9
    N114 G2 X-101.4 Y-59.9 R31.5
    N115 G1 Y59.9
    N116 G2 X-69.9 Y91.4 R31.5
    N117 G1 X69.9
    N118 G2 X101.4 Y59.9 R31.5
    N119 G1 Y-59.9
    N120 G2 X69.9 Y-91.4 R31.5
    N121 G1 Y-93.4
    N122 G0 Z10
    N123 G0 Y-116.4
    N124 G0 Z-33
    N125 G1 Z-40 F1200
    N126 G1 X87.578 Y-98.722 F1000
    N127 G3 X69.9 Y-91.4 R25
    N128 G1 X-69.9
    N129 G2 X-101.4 Y-59.9 R31.5
    N130 G1 Y59.9
    N131 G2 X-69.9 Y91.4 R31.5
    N132 G1 X69.9
    N133 G2 X101.4 Y59.9 R31.5
    N134 G1 Y-59.9
    N135 G2 X69.9 Y-91.4 R31.5
    N136 G1 Y-93.4
    N137 G0 Z10
    N138 G0 Y-116.4
    N139 G0 Z-38
    N140 G1 Z-45 F1200
    N141 G1 X87.578 Y-98.722 F1000
    N142 G3 X69.9 Y-91.4 R25
    N143 G1 X-69.9
    N144 G2 X-101.4 Y-59.9 R31.5
    N145 G1 Y59.9
    N146 G2 X-69.9 Y91.4 R31.5
    N147 G1 X69.9
    N148 G2 X101.4 Y59.9 R31.5
    N149 G1 Y-59.9
    N150 G2 X69.9 Y-91.4 R31.5
    N151 G1 Y-93.4
    N152 G0 Z10
    N153 G0 Y-116.4
    N154 G0 Z-43
    N155 G1 Z-50 F1200
    N156 G1 X87.578 Y-98.722 F1000
    N157 G3 X69.9 Y-91.4 R25
    N158 G1 X-69.9
    N159 G2 X-101.4 Y-59.9 R31.5
    N160 G1 Y59.9
    N161 G2 X-69.9 Y91.4 R31.5
    N162 G1 X69.9
    N163 G2 X101.4 Y59.9 R31.5
    N164 G1 Y-59.9
    N165 G2 X69.9 Y-91.4 R31.5
    N166 G1 Y-93.4
    N167 G0 Z10
    N168 G0 Y-116.4
    N169 G0 Z-48
    N170 G1 Z-55 F1200
    N171 G1 X87.578 Y-98.722 F1000
    N172 G3 X69.9 Y-91.4 R25
    N173 G1 X-69.9
    N174 G2 X-101.4 Y-59.9 R31.5
    N175 G1 Y59.9
    N176 G2 X-69.9 Y91.4 R31.5
    N177 G1 X69.9
    N178 G2 X101.4 Y59.9 R31.5
    N179 G1 Y-59.9
    N180 G2 X69.9 Y-91.4 R31.5
    N181 G1 Y-93.4
    N182 G0 Z10
    N183 G0 Y-116.4
    N184 G0 Z-53
    N185 G1 Z-58.9 F1200
    N186 G1 X87.578 Y-98.722 F1000
    N187 G3 X69.9 Y-91.4 R25
    N188 G1 X-69.9
    N189 G2 X-101.4 Y-59.9 R31.5
    N190 G1 Y59.9
    N191 G2 X-69.9 Y91.4 R31.5
    N192 G1 X69.9
    N193 G2 X101.4 Y59.9 R31.5
    N194 G1 Y-59.9
    N195 G2 X69.9 Y-91.4 R31.5
    N196 G1 Y-93.4
    N197 G0 Z10
    N198 G0 X0 Y0 Z200
    N199 T0 M6
    N200 M9
    N201 M30
    also , regarding the instructions to work on DNC mode, you told me :
    "Ok so if you want to transfer from the pc to the machine do this : press the MANUAL KEY than press the Prog Mem key then press F5 , You should see a list of programs stored in memory , Now type the number of the program you want to transfer from the pc . it should be a number above 9000 . After you have typed the number pres the Enter key once , now press the Data In out key an finally press F2 for input"
    All of this is ok , and it works, but it to store programs in memory, it did not go into DNC mode.
    any suggestions ?
    Hy ,
    I see you use G17 meaning XY plane to program , are you using the horizontal spindle or you have changed the axis from the machine parameters? I ask you because normally on Maho machines you use G18 XZ plane for the vertical spindle. The program you sent me will crash the part or machine.
    To get into DNC mode you must pres Manual key, then Menu key , then the corresponding number key for Search ,I believe it's 2 or 3 depending on your machine , and finally the soft key F3 under BTR MODE ON. To verify you;ve entered BTR mode just pres Prog MEM key and you will not be able to see the programs list like before. Now there is the matter of adjusting the size of the machine constant called BTR MACRO SIZE, because by default it's too big. As I told you before if is left too big it will transfer program lines until the memory will overflow and stop the program completely, if it's left too little it will execute a couple of lines then stop the feed of the machine and transfer some more lines and so on.
    To exit BTR mode do the same steps again , or just turn off the machine and it will go back to normal mode.
    Regards
    Mar 2016
    22
    Hy ,
    Regards
    I did not wrote this G-code, I took it from another post just for testing purposes.
    I press as you told me Manual key, then Menu key, then I press 1 (to choose "block search") ,and then I found the soft key F3 does not have any function inside block search option. there is nothing exist in that page to activate the BTR. I do not know why.
    thanks
    Hello,
    It is possible that your machine is not equipped with the module for BTR, In this case you should limit your programs to about 5000 to 6000 lines or just divide a larger program into sections. I've done this in the past but it is annoying. Send me your machine's software version and exact model and year of make , I will look into it.
    Regards
    Jun 2016
    4
    Hi!
    Previously only used Siemens 840D controler.
    Now I bought an Maho Graziano 300 C-type lathe with Philips 432 controller. The machine program storage is empty. I want to create a new program, but will not allow it because the Soft-Key Lock and I do not know how can I Unlock. The Soft-Key does not work. The instruction manual says that there is an external key. When I turn the key on the keyboard it will not work.
    Manual:
    "Es ist zu sehen, dass die Soft-Taste LOCK angezeigt ist.
    Mit einem externen Schalter kann jedes Teileprogramm in Speicher gesperrt werden (damit es nicht editieren werden kann) und die Sperre der aufgehoben werden. Zusatzlich zu einem externen Schalter kann eine Maschinenkonstante so eingestellt werden, dass ein Teileprogramm mit einer Soft-Taste gesperrt oder freigegeben werden kann (LOCK oder UNLOCK) siehe "Interfacing and Installácion Manual".
    Ein Teileprograram kann folgendermassen gesperrt werden:
    - Teile prograramm nummer mit den Zeilenwahltasten wahlen
    - Soft-Taste >LOCK< drücken."
    Thanks for the help!
    Feb 2006
    12
    Nice thread! Some good information here.
    Can you explain how you setup the connection between your pc and the maho?
    I'm trying to transfer programs (and later try to use the BTR function) from PC to Maho, but after 8 lines of code the transfer stops and an error "Data interupted" pops up.
    Transferring data from Maho to PC goes fine though.
    Can you post your machine constants N770, 771, 772, 773, 774, 775 and 776? And what sort of serial cable and pc program do you use?
    I tried hyperterminal, proezdnc and TNCremo but no luck so far :-(.
    Thanks,
    Hello, sory for The delay in ansewering, I was away for a few months. I will gave you a detailed answer soon if you are still interested
    Quote Originally Posted by john huijben View Post
    Thanks,
  17. #17
    Sep 2010
    27
    Hello.
    Viorel23cnc must be forgotten about this, or something happened.
    Anybody have the correct parameters for DTR?
    Attachment 349082
  18. #18
    hello guys.
    i have similar problem. at me is the menu BTR is not available. do somebody know how to set the variables to get this functionality.
    my machine has software version 6701.703/03
    sorry for bad english
    thank you very much
  19. #19
    Hello
    Give me more details. about your problem. Did you try Manual key + Menu + 1 for Block search + F3 (in the program list not the actual program) for btr on ?
  20. #20
    Feb 2010
    31
    Hello
    Please help me with the parameters for one MAHO GRAZIANO MT 600 C, the machine has not operated for 4 years and has lost all parameters.
    CNC: Philips 532 T / 8 ; Turret SAUTER
    Thank you very much!
    http://mymillcnc.uv.ro
    http://freenergy.uv.ro
Page 1 of 2 12
  1. MAHO 900C with Philips CNC 432
    By ua_gs in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-24-2016, 09:51 AM
  2. PHILIPS 432 (MAHO MC50)
    By abbas in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-24-2009, 10:17 AM
  3. MAHO-PHILIPS 432 M60 and G23 problem
    By micktat in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-03-2009, 11:10 PM
  4. Maho 650 - CNC 532 Philips
    By nylas in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-13-2007, 07:41 PM
