525,803 active members*
3,008 visitors online*
Results 1 to 7 of 7
    Aug 2009
    5
    Make mach3 gcode with solidcam
    How cam I produce g code for mach3 with solidcam. I saw here ara some post processors for that but I could not find any.
    Can someone help
    Tanks
    Sacramento
    Jan 2017
    13
    Here you go: https://github.com/teodoryantcheff/SolidCam-Mach3-Post
    Only thing I did not manage to solve yet is how to do multiple operations in one gcode file. The @start_of_job section is somehow ignored for the 2nd operation. No issue if you do not change tools or spindle speed or cooling....
    Quote Originally Posted by sacramento View Post
    Can someone help
    Tanks
    Sacramento
    Nov 2012
    8
    Re: Make mach3 gcode with solidcam
    if you need a SC pp, you can pm me.
    Feb 2009
    10
    if you read the GPPTool documentation, you might be able to understand how the post processor works. Most of the posts that come with solidcam have variables that can be set or changed to make the processor do what you want. I was able to modify the gMilling_3x post processor and it does a wonderful job with my machine and mach3. better than the posts that i found floating around online.
    Oct 2017
    7
    Quote Originally Posted by ironspyder View Post
    Hi is it posibel to have a copy of yous.
    Sep 2005
    1113
    Quote Originally Posted by fly44 View Post
    Hello, I built my own CNC 3X and works with mach3, I would like to have a PP for solid am to have Better results, can you share?
  1. Solidcam 2014 tool table setup and gcode template
    By brightprojects in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-27-2016, 11:15 PM
  2. need someone to make part's gcode
    By xclr82xtc in forum Mastercam
    Last Post: 06-14-2010, 02:11 PM
  3. Odd message when I try to make Gcode
    By Crawler374 in forum CamBam
    Last Post: 09-21-2009, 09:07 AM
  4. FANUC GCode from SolidCAM
    By Jixxer in forum G-Code Programing
    Last Post: 09-04-2009, 07:52 AM
  5. Solidcam output weird Gcode
    By kn6398 in forum Solidworks
    Last Post: 03-19-2009, 01:55 AM
