540,707 active members*
6,582 visitors online*
    Manual control arrows - how to make inactive?
    Please help me.
    How do I make the manual control arrows on the KMotionCNC panel inactive (turn off)? See the photo - circled in red. So that I can then turn it on if necessary.
    I need it in order that the operator does not accidentally press button unnecessary.
    Re: Manual control arrows - how to make inactive?
    Junior Member
    May 2006
    3744
    The Jog Buttons do automatically disable while a Job is running. It's not common to want do disable them when the machine is idle. We don't have a command to do that. We have commands to do the opposite. To re-enable them while a Job is running. Some MCodes might require the Operator to Jog for some purpose. These commands will allow this:
    #define PC_COMM_ENABLE_JOG_KEYS 37 // Allow User to Push Jog Buttons while JOB is running
    #define PC_COMM_DISABLE_JOG_KEYS 38 // Disable allowing User to Push Jog Buttons while Job is Running
    Otherwise the only solution I can think of would be to switch to a custom screen without the buttons present or functional. Or to change the KMotionCNC Source code.
    TK
    http://dynomotion.com
  1. Replies: 1
    Last Post: 01-18-2020, 11:31 PM
  2. Replies: 0
    Last Post: 03-18-2016, 10:55 PM
  3. I NEED: DX-32 manual, 1104-2832 VMC Operator's Manual, DX-32 CNC Control
    By vettespeed in forum Bridgeport / Hardinge Mills
    Last Post: 05-31-2012, 02:21 AM
  4. dnc inactive on M2 control
    By apylus444 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-01-2008, 02:04 PM
