541,112 active members*
2,264 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Manual entry - what variable name holds the 1006 comment string?
    Aug 2005
    118
    Hi. tinkering with an old post made for V8.1. Trying to look at the manual entry comment string before its output for a word in the programmer's comment, then output the comment and change a few codes if the word is present. We have this trick working on our mills, but cant seem to find what variable name the lathe package is hiding the manual entry comment in. Its not Scomm0.
    Thanks.
    Apr 2021
    4
    Re: Manual entry - what variable name holds the 1006 comment string?
  1. Cant get X axis to zero out (manual position entry)
    By Scott Riddle in forum Mach Lathe
    Last Post: 01-10-2021, 06:34 PM
  2. Fanuc 6T - comment entry
    By bkelsey in forum Fanuc
    Last Post: 04-09-2019, 12:04 PM
  3. Replies: 0
    Last Post: 12-26-2017, 08:13 AM
  4. Replies: 3
    Last Post: 06-03-2016, 04:49 AM
  5. Manual entry as code in X2
    By horst007 in forum Mastercam
    Last Post: 08-20-2008, 10:19 PM
