Re: Manual Guide question
Originally Posted by
nikolas98
Good afternoon. On our NL Smart 4500 machine, when operating in manual guide mode, in simulation mode, the coordinates are displayed incorrectly. How can this be avoided? Incorrectly displayed only in simulation mode, machine with Y axis
Check the Work Coordinate System (G54, G55, etc.)
make sure that the correct work offset is set before running the simulation.
If an incorrect offset is active, the simulated coordinates may not match actual machining.
