593,377 active members*
6,666 visitors online*
Results 1 to 5 of 5
    Mass tool offset
    I'm here hoping someone can help. Is there any way of changing all your tool lengths at once without doing each tool individually. Trying to compensate for matching growth on a 5 axis with 28 tools
    TIA
    Re: Mass tool offset
    if your tools don't leave to holders between jobs then once your tools are qualified and documented you can add g10 at the header of the program for each tool .
    An alternative if your using the gage line method -- preset your tools with the external tool setter , document the tools and create a program or edit into your program once again with g10's . It's a pita but it can be done while another job is running and will minimize down time
    Otherwise I can't see any way of qualifying all the tools in one shot if they are being qualified in the machine , they'll have to be qualified individually
    Mar 2003
    927
    You can add / subtract the Z length of all tools by changing the work offset Z value. (IE: G55 Z value from say 0 To +.005 or -.005)
    Mar 2016
    333
    It won't work for 5axes movbement control.
    U can download offsets to computer (it's simple txt file), add values in eg excel, and upload file back to machine.
    I was thinking a completely different thing when I posted lol . The above makes the most sense for editing them all together
  1. Replies: 9
    Last Post: 04-03-2024, 09:33 PM
  2. Tool offset with work offset
    By botha.y in forum SIEMENS -> GENERAL
    Last Post: 06-04-2012, 06:31 PM
  3. Tool offset with work offset
    Last Post: 05-28-2012, 09:48 PM
