585,758 active members*
4,572 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam X4 3d contour not following contour
Results 1 to 4 of 4
    Jul 2006
    10
    Hello all,
    I've searched and can't find an answer to this so I'm finally posting. This should be (and probably is) really simple but I can't figure it out. I'm just trying to mill a 3d contour with the 2D contour operation using 3D as contour type but it's not following the contour as seen on the attached. I would like to step it .010" as well. I'm sure I haven't given enough information so please let me know. Thanks for any help you can give!
    Mastercam X4 lvl 3
    Thanks,
    Doug
    Sep 2020
    14
    Re: Mastercam X4 3d contour not following contour
    You need to program the center of your tool instead of the tip.
    Jul 2006
    10
    Hey Thanks! I changed it to center and offset it 3/16 and it looks like it's going to work. Thanks again!
    Sep 2020
    14
    Hell yeah dude!
  1. Replies: 3
    Last Post: 11-23-2017, 01:21 AM
  2. Mastercam X5 - Ramp on contour
    By adam_m in forum Mastercam
    Last Post: 02-06-2017, 06:51 PM
  3. Mastercam Help 2d Contour toolpath
    By Hammax in forum Mastercam
    Last Post: 04-17-2016, 01:26 PM
  4. mastercam contour faceted cut
    By fjbart70 in forum Mastercam
    Last Post: 06-28-2011, 09:23 PM
  5. Contour on Surface. Mastercam 9
    By kram941 in forum Mastercam
    Last Post: 06-25-2009, 05:12 PM
