538,105 active members*
2,323 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > MasterWood CNC Router No File Access Possible Error.
    Jan 2018
    5
    Exclamation MasterWood CNC Router No File Access Possible Error.
    We recently got a Masterwood Project 360 CNC Router. We have a problem after loading a program in Master AT software, and start program, then it stops and says ERROR 20346 NO FILE ACCESS POSSIBLE.
    Does anybody know how to fix this?
    Nov 2009
    5
    Re: MasterWood CNC Router No File Access Possible Error.
    The machine has Beckhoff CNC, probably a sub program (cycle) called from the main program created by MasterAT is missing. In the errore message You can find which is the cycle missing
  1. Fanuc controller can access the files in FTP server but gives file size error
    By Semih__ in forum Controller & Computer Solutions
    Last Post: 11-19-2018, 11:51 PM
  2. Masterwood 327 Problem - Error code 0.0.0090
    By Master327 in forum CNC Machining Centers
    Last Post: 10-17-2018, 12:14 PM
  3. Slow file access
    By Michael M in forum Centroid CNC Control Products
    Last Post: 05-22-2018, 05:14 AM
  4. M70 Mitsubishi CNC Controller Program file access through Ethernet
    By sachincool786 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-26-2016, 03:36 PM
  5. Masterwood 327 Error codes
    By cure1 in forum CNC Machining Centers
    Last Post: 06-07-2012, 02:30 PM
